福州三森机械有限公司生产的无卡旋切机BQ18系列
BQ1813/3A数控无卡轴旋切机NC.Spindleless Veneer Lathe
产品概述
· 适合加工小径木及木芯的芯(面)板。· 三辊采用优质圆钢拉槽后镀耐磨鉻· 滑枕导轨采用铸件而成,耐用稳定。· 采用后辊拉压尺辊的进给方式,配合丝杆铜螺母,既节约动力又提高了单板均匀度。· 采用具有独立知识产权的凸轮随动装置技术,单板均匀,表面光滑· 机身主要构件经过特殊处理,强度好,不变形
Product outline
· Suitable for processing small diameter wood and the wood core of the core (face) veneer.· Roll: Quality round steel trench, wear-resistant chrome.· Ram guide: casting made, durable and stable.· Feed system: back roll pull pressure bar roll, co-action with screw and copper nut, small power consumption and high uniform thickness of veneer.· Cam follower device with independent intellectual property rights produce smooth and uniform veneer suface.· Main components of machine: special handling, high strength and not easy deformation
基本参数 MAJORTECHNICALPARAMETERS
名称 DESCRIPTION单位UNITBQ1813/3A
旋切原木长度 Length of peeler log mm1000-1300
旋切原木直径 Diameter of peeler logmmφ25-φ300
刀片长度Length of blademm1400
旋切单板厚度Thickness of veneer peelermm0.5-3.6
刀架快速移动速度Fast-forward speed of tool restmm/min1000
主机线速度Linear speed of host machinem/min40
传动辊电机功率Power of driving rollerKW5.5
压尺辊电机功率Power of pressurebar rollerKW5.5
走刀电机功率Power of cutting feed KW5.5
总功率Total powerKW16.5
总重量Total weightkg3200
外形尺寸Overall dimensionsmm2400*1700*1450
没知道做什么用的!!!! 旋切木轴的,,,,,,,,,,,,,,,,
