我公司使用的SKF大型加热器TIH 210m
<TABLE cellSpacing=0 cellPadding=0 width=410 border=0><TBODY>
<TR>
<TD class=head></TD></TR>
<TR>
<TD> </TD></TR>
<TR>
<TD><IMG height=166 src="http://www.mapro.skf.com/images/h_tih210m.jpg" width=400 border=0></TD></TR>
<TR>
<TD> </TD></TR>
<TR>
<TD><B>Heating a 210 kg bearing now takes as long as a coffee break</B> </TD></TR>
<TR>
<TD> </TD></TR>
<TR>
<TD>The TIH 210m is an extremely efficient large-size induction heater, which is capable of heating a 210 kg (460 lb) bearing in just 20 minutes. This incredible speed is achieved by positioning the induction coil outside the heater's housing, allowing the bearing to be placed around the coil. This significant innovation results in reducing heating time and power consumption by up to 30%, ultimately saving up to 50% on heating costs.</TD></TR>
<TR>
<TD> </TD></TR>
<TR>
<TD>
<TABLE cellSpacing=0 cellPadding=0 border=0>
<TBODY>
<TR>
<TD vAlign=top><IMG height=10 src="http://www.mapro.skf.com/images/blackbullet.gif" width=12 border=0></TD>
<TD vAlign=top>Thermal overheating protection of the induction coil and electronics</TD></TR>
<TR>
<TD vAlign=top>Time and temperature modes for heating components other than bearings</TD></TR>
<TR>
<TD vAlign=top>Automatic demagnetisation</TD></TR>
<TR>
<TD vAlign=top>One power supply execution ranging from 400V/50Hz to 460V/60Hz, the SKF TIH 210m detects the power supply and automatically adjusts its voltage accordingly</TD></TR>
<TR>
<TD vAlign=top>Compact design</TD></TR></TBODY></TABLE></TD></TR>
<TR>
<TD> </TD></TR>
<TR>
<TD><B>SKF m<SUB>20</SUB> concept</B><BR>"m<SUB>20</SUB>" represents the weight (kg) of the heaviest SRB 231 bearing which can be heated from 20 to 110 °C (68 to 230 °F) in 20 minutes. This defines the heater's power output instead of its power input: kVA.</TD></TR>
<TR>
<TD> </TD></TR>
<TR>
<TD>
<TABLE class=border cellSpacing=0 cellPadding=0 width=400 border=0>
<TBODY>
<TR vAlign=top>
<TD align=middle colSpan=2><IMG height=307 src="http://www.mapro.skf.com/images/h_tih210m_2.jpg" width=400 border=0></TD></TR>
<TR vAlign=top>
<TD class=sdg align=left> A </TD>
<TD class=sdg align=left>Induction coil outside the heater's housing</TD></TR>
<TR vAlign=top>
<TD class=s align=left></TD>
<TD class=s align=left>Reduces heating time and energy consumption by 80%</TD></TR>
<TR vAlign=top>
<TD class=s align=left>Reduces heating cost by 70%</TD></TR>
<TR vAlign=top>
<TD class=sdg align=left> B</TD>
<TD class=sdg align=left>Magnetic temperature probe</TD></TR>
<TR vAlign=top>
<TD class=s align=left>Monitors bearing temperature during heating</TD></TR>
<TR vAlign=top>
<TD class=sdg align=left> C</TD>
<TD class=sdg align=left>Operating panel</TD></TR>
<TR vAlign=top>
<TD class=s align=left>Keyboard with LED</TD></TR>
<TR vAlign=top>
<TD class=s align=left>Temperature mode pre-set at 110 °C (230 °F), helps preventing bearing overheating</TD></TR>
<TR vAlign=top>
<TD class=sdg align=left> D</TD>
<TD class=sdg align=left>4-step power reduction</TD></TR>
<TR vAlign=top>
<TD class=s align=left>Heats smaller bearings just as quickly but at lower power consumption</TD></TR>
<TR vAlign=top>
<TD class=sdg align=left> E</TD>
<TD class=sdg align=left>Integrated carrying handles</TD></TR>
<TR vAlign=top>
<TD class=s align=left>Provide excellent grip when moving the heaters around</TD></TR>
<TR vAlign=top>
<TD class=sdg align=left> F</TD>
<TD class=sdg align=left>Internal yoke storage</TD></TR>
<TR vAlign=top>
<TD class=s align=left>Storage for the extra yokes reduces the risk of yoke damage or loss</TD></TR></TBODY></TABLE></TD></TR>
<TR>
<TD> </TD></TR>
<TR>
<TD>
<TABLE class=border cellSpacing=0 cellPadding=0 border=0>
<TBODY>
<TR>
<TD class=db colSpan=3> Technical data</TD></TR>
<TR>
<TD class=db colSpan=3><IMG height=1 src="http://www.mapro.skf.com/images/blackdot.gif" width=400 border=0></TD></TR>
<TR>
<TD class=slb colSpan=2> Designation</TD>
<TD class=slb>TIH 210m</TD></TR>
<TR>
<TD class=s colSpan=2> Description</TD>
<TD class=s>Large size induction heater</TD></TR>
<TR>
<TD class=sdg colSpan=2> SKF m<SUB>20 </SUB>performance</TD>
<TD class=sdg>210 kg (460 lb)</TD></TR>
<TR>
<TD class=s colSpan=2> Voltage, V/Hz</TD>
<TD class=s>Self-adjusting; 400/50 - 460/60</TD></TR>
<TR>
<TD class=sdg colSpan=2> Work piece</TD>
<TD class=sdg></TD></TR>
<TR>
<TD class=sdg> - </TD>
<TD class=sdg>Maximum weight</TD>
<TD class=sdg>300 kg (660 lb)</TD></TR>
<TR>
<TD class=sdg>Maximum bore diameter</TD>
<TD class=sdg>60 - 600 mm (2.4 - 24 in)</TD></TR>
<TR>
<TD class=s colSpan=2> Temperature control</TD>
<TD class=s></TD></TR>
<TR>
<TD class=s> - </TD>
<TD class=s>Range</TD>
<TD class=s>0 - 250 °C (32 - 482 °F)</TD></TR>
<TR>
<TD class=s>Magnetic probe</TD>
<TD class=s>Yes, K-type</TD></TR>
<TR>
<TD class=s>Accuracy (electronics)</TD>
<TD class=s>± 3 °C (± 5 °F)</TD></TR>
<TR>
<TD class=sdg colSpan=2> Time control</TD>
<TR>
<TD class=sdg>Range</TD>
<TD class=sdg>0 - 60 minutes</TD></TR>
<TR>
<TD class=sdg>Accuracy</TD>
<TD class=sdg>± 0,01 sec.</TD></TR>
<TR>
<TD class=s colSpan=2> Maximum temperature (approx.) </TD>
<TD class=s>400 °C (750 °F)</TD></TR>
<TR>
<TD class=sdg colSpan=2> Thermometer mode</TD>
<TD class=sdg>Yes</TD></TR>
<TR>
<TD class=s colSpan=2> Bearing temperature preset</TD>
<TD class=s>Yes</TD></TR>
<TR>
<TD class=sdg colSpan=2> Power reduction</TD>
<TD class=sdg>4-step; 20-40-60-80%</TD></TR>
<TR>
<TD class=s colSpan=2> Demagnetisation according to <BR>SKF norms (automatic)</TD>
<TD class=s>Yes (<2 A/cm)</TD></TR>
<TR>
<TD class=sdg colSpan=2> Can heat sealed bearings</TD>
<TR>
<TD class=s colSpan=2> Can heat pre-greased bearings</TD>
<TR>
<TD class=sdg colSpan=2> Error guiding codes</TD>
<TR>
<TD class=s colSpan=2> Thermal overload protection</TD>
<TR>
<TD class=sdg colSpan=2> Maximum magnetic flux</TD>
<TD class=sdg>1,5 T</TD></TR>
<TR>
<TD class=s colSpan=2> Control panel</TD>
<TD class=s>Key board with LED</TD></TR>
<TR>
<TD class=sdg colSpan=2> Operating area (w x h)</TD>
<TD class=sdg>250 x 250 mm (9.8 x 9.8 in)</TD></TR>
<TR>
<TD class=s colSpan=2> Coil diameter</TD>
<TD class=s>135 mm (5.3 in)</TD></TR>
<TR>
<TD class=sdg colSpan=2> Dimensions (w x d x h)</TD>
<TD class=sdg>600 x 350 x 420 mm (24 x 13.7 x 16.5 in) </TD></TR>
<TR>
<TD class=s colSpan=2> Total weight, including yokes </TD>
<TD class=s>75 kg (165 lb) </TD></TR>
<TR>
<TD class=sdg colSpan=2> Maximum power</TD>
<TD class=sdg>10,0 kVA</TD></TR>
<TR>
<TD class=s colSpan=2> Number of standard yokes</TD>
<TD class=s>2</TD></TR>
<TR>
<TD class=sdg colSpan=2> Standard yokes</TD>
<TD class=sdg>70 x 70 x 420 mm (2.8 x 2.8 x 16.5 in), </TD></TR>
<TR>
<TD class=sdg colSpan=2> </TD>
<TD class=sdg>for heating bearings with bore</TD></TR>
<TR>
<TD class=sdg>diameter of 100 mm (3.9 in) and larger.</TD></TR>
<TR>
<TD class=sdg>40 x 40 x 420 mm (1.6 x 1.6 x 16.5 in), </TD></TR>
<TR>
<TR>
<TD class=sdg>diameter of 60 mm (2.4 in) and larger.</TD></TR>
<TR>
<TD class=s colSpan=2> Core cross section</TD>
<TD class=s>70 x 70 mm (2.8 x 2.8 in)</TD></TR>
<TR>
<TD class=sdg colSpan=2> Yoke storage</TD>
<TD class=sdg>Yes, internal</TD></TR>
<TR>
<TD class=s colSpan=2> Sliding arm</TD>
<TR>
<TD class=sdg colSpan=2> Swivel arm</TD>
<TD class=sdg>-</TD></TR>
<TR>
<TD class=s colSpan=2> Cooling fan</TD>
<TD class=s>Optional</TD></TR>
<TR>
<TD class=sdg colSpan=2> Housing material</TD>
<TD class=sdg>Aluminium</TD></TR>
<TR>
<TD class=s colSpan=2> Warranty period</TD>
<TD class=s>3 years</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
Re: 我公司使用的SKF大型加热器TIH 210m
顺便附上说明书以及使用维护手册,不过是英文版的,没有中文的!回复 1# 漂流瓶 的帖子
看来你单位SKF用的不少啊。 :handshake太厉害啦,连SKF加热器都能用得上,来头不少。skf轴承经销商,欢迎来电来函。佛山正大机电轴承有限公司 刘伟达 0757-83960763 真的很不错,我只看过小轴承的加热器 SKF加热器都能用得上,来头不少。skf轴承经销商,欢迎来电来函。0531-88660088
