hanxf 发表于 2006-4-11 12:30:08
CAD使用六则
<DIV align=center>
<TABLE class=MsoNormalTable style="WIDTH: 100%; mso-cellspacing: 1.5pt" cellPadding=0 width="100%" border=0>
<TBODY>
<TR style="HEIGHT: 7.5pt; mso-yfti-irow: 0; mso-yfti-firstrow: yes">
<TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0.75pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #d4d0c8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 7.5pt; BACKGROUND-COLOR: transparent">
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; WORD-BREAK: break-all; TEXT-INDENT: 135.55pt; TEXT-ALIGN: left; mso-char-indent-count: 10.0; mso-pagination: widow-orphan" align=left><STRONG><SPAN lang=EN-US style="FONT-SIZE: 13.5pt; COLOR: black"><FONT face="Times New Roman">CAD</FONT></SPAN></STRONG><STRONG><SPAN style="FONT-SIZE: 13.5pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">使用六则</SPAN></STRONG><SPAN lang=EN-US style="FONT-SIZE: 8pt; COLOR: black; FONT-FAMILY: 宋体; mso-bidi-font-size: 9.0pt; mso-bidi-font-family: 宋体; mso-font-kerning: 0pt"><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P></TD></TR>
<TR style="mso-yfti-irow: 1; mso-yfti-lastrow: yes">
<TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0.75pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #d4d0c8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent">
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; WORD-BREAK: break-all; TEXT-ALIGN: left; mso-pagination: widow-orphan" align=left><SPAN style="COLOR: black; FONT-FAMILY: 宋体; mso-bidi-font-size: 10.5pt; mso-bidi-font-family: 宋体; mso-font-kerning: 0pt">一、<SPAN lang=EN-US> AutoCAD</SPAN>表格制作<SPAN lang=EN-US> <BR>AutoCAD</SPAN>尽管有强大的图形功能,但表格处理功能相对较弱,而在实际工作中,往往需要在<SPAN lang=EN-US>AutoCAD</SPAN>中制作各种表格,如工程数量表等,如何高效制作表格,是一个很实用的问题。<SPAN lang=EN-US> <BR></SPAN>在<SPAN lang=EN-US>AutoCAD</SPAN>环境下用手工画线方法绘制表格,然后,再在表格中填写文字,不但效率低下,而且,很难精确控制文字的书写位置,文字排版也很成问题。尽管<SPAN lang=EN-US>AutoCAD</SPAN>支持对象链接与嵌入,可以插入<SPAN lang=EN-US>Word</SPAN>或<SPAN lang=EN-US>Excel</SPAN>表格,但是一方面修改起来不是很方便,一点小小的修改就得进入<SPAN lang=EN-US>Word</SPAN>或<SPAN lang=EN-US>Excel</SPAN>,修改完成后,又得退回到<SPAN lang=EN-US>AutoCAD</SPAN>,另一方面,一些特殊符号如一级钢筋符号以及二级钢筋符号等,在<SPAN lang=EN-US>Word</SPAN>或<SPAN lang=EN-US>Excel</SPAN>中很难输入,那么有没有两全其美的方法呢,经过探索,可以这样较好解决:先在<SPAN lang=EN-US>Excel</SPAN>中制完表格,复制到剪贴板,然后再在<SPAN lang=EN-US>AutoCAD</SPAN>环境下选择<SPAN lang=EN-US>edit</SPAN>菜单中的<SPAN lang=EN-US>Paste special</SPAN>,选择作为<SPAN lang=EN-US>AutoCAD Entities</SPAN>,确定以后,表格即转化成<SPAN lang=EN-US>AutoCAD</SPAN>实体,用<SPAN lang=EN-US>explode</SPAN>炸开,即可以编辑其中的线条及方字,非常方便。<SPAN lang=EN-US> <BR><BR></SPAN>二、在<SPAN lang=EN-US>Word</SPAN>文档中插入<SPAN lang=EN-US>AutoCAD</SPAN>图形<SPAN lang=EN-US> <BR>Word</SPAN>文档制作中,往往需要各种插图,<SPAN lang=EN-US>Word</SPAN>绘图功能有限,特别是复杂的图形,该缺点更加明显,<SPAN lang=EN-US>AutoCAD</SPAN>是专业绘图软件,功能强大,很适合绘制比较复杂的图形,用<SPAN lang=EN-US>AutoCAD</SPAN>绘制好图形,然后插入<SPAN lang=EN-US>Word</SPAN>制作复合文档是解决问题的好办法,可以用<SPAN lang=EN-US>AutoCAD</SPAN>提供的<SPAN lang=EN-US>EXPORT</SPAN>功能先将<SPAN lang=EN-US>AutocAD</SPAN>图形以<SPAN lang=EN-US>BMP</SPAN>或<SPAN lang=EN-US>WMF</SPAN>等格式输出,然后插入<SPAN lang=EN-US>Word</SPAN>文档,也可以先将<SPAN lang=EN-US>AutoCAD</SPAN>图形拷贝到剪贴板,再在<SPAN lang=EN-US>Word</SPAN>文档中粘贴。须注意的是,由于<SPAN lang=EN-US>AutoCAD</SPAN>默认背景颜色为黑色,而<SPAN lang=EN-US>Word</SPAN>背景颜色为白色,首先应将<SPAN lang=EN-US>AutoCAD</SPAN>图形背景颜色改成白色。另外,<SPAN lang=EN-US>AutoCAD</SPAN>图形插入<SPAN lang=EN-US>Word</SPAN>文档后,往往空边过大,效果不理想。利用<SPAN lang=EN-US>Word</SPAN>图片工具栏上的裁剪功能进行修整,空边过大问题即可解决。<SPAN lang=EN-US> <BR><BR></SPAN>三、线宽修改<SPAN lang=EN-US> <BR>AutoCAD</SPAN>提供了一个多义线线宽修改命令<SPAN lang=EN-US>PEDIT</SPAN>,来进行多义线线宽的修改(若不是多义线,则该命令将先转化成多义线,再改变其线宽),但是<SPAN lang=EN-US>PEDIT</SPAN>操作繁,每次只能选取<SPAN lang=EN-US>1</SPAN>个实体操作,效率低下。<SPAN lang=EN-US>AutoCAD R14</SPAN>附赠程序<SPAN lang=EN-US>Bonus</SPAN>提供了<SPAN lang=EN-US>mpedit</SPAN>命令,用于成批修改多义线线宽,非常方便高效。在<SPAN lang=EN-US>AutoCAD2000</SPAN>中,还可给实体指定线宽(<SPAN lang=EN-US>LineWeight</SPAN>)属性修改线宽,只需选择要改变线宽的实体(实体集),改变线宽属性即可,线宽修改更加方便,须注意的是,<SPAN lang=EN-US>LineWeight</SPAN>属性线宽在屏幕的显示与否决定于系统变量<SPAN lang=EN-US>LWDISPLAY</SPAN>,该变量为<SPAN lang=EN-US>ON</SPAN>,则在屏幕上显示<SPAN lang=EN-US>LineWeight</SPAN>属性线宽,该变量为<SPAN lang=EN-US>OFF</SPAN>,则不显示。多义线线宽同<SPAN lang=EN-US>LineWeight</SPAN>都可控制实体线宽,两者之间的区别是,<SPAN lang=EN-US>LineWeight</SPAN>线宽是绝对线宽,而多义线线宽是相对线宽,也就是说,无论图形以多大尺寸打印,<SPAN lang=EN-US>LineWeight</SPAN>线宽都不变,而多义线线宽则随打印尺寸比例大小变化而变化,命令<SPAN lang=EN-US>scale</SPAN>对<SPAN lang=EN-US>LineWeight</SPAN>线宽没什么影响,无论实体被缩放多少倍,<SPAN lang=EN-US>LineWeight</SPAN>线宽都不变,而多义线线宽则随缩放比例改变而改变。<SPAN lang=EN-US> <BR><BR></SPAN>四、 图形的打印技巧<SPAN lang=EN-US> <BR></SPAN>由于没有安装打印机或想用别人高档打印机输入<SPAN lang=EN-US>AutoCAD</SPAN>图形,需要到别的计算机去打印<SPAN lang=EN-US>AutoCAD</SPAN>图形,但是别的计算机也可能没安装<SPAN lang=EN-US>AutoCAD</SPAN>,或者因为各种原因(如<SPAN lang=EN-US>AutoCAD</SPAN>图形在别的计算机上字体显示不正常,通过网络打印,网络打印不正常等),不能利用别的计算机进行正常打印,这时,可以先在自己计算机上将<SPAN lang=EN-US>AutoCAD</SPAN>图形打印到文件,形成打印机文件,然后,再在别的计算机上用<SPAN lang=EN-US>DOS</SPAN>的拷贝命令将打印机文件输出到打印机,方法为:<SPAN lang=EN-US>copy </SPAN><打印机文件><SPAN lang=EN-US> prn /b</SPAN>,须注意的是,为了能使用该功能,需先在系统中添加别的计算机上特定型号打印机,并将它设为默认打印机,另外,<SPAN lang=EN-US>COPY</SPAN>后不要忘了在最后加/<SPAN lang=EN-US>b</SPAN>,表明以二进制形式将打印机文件输出到打印机。<SPAN lang=EN-US> <BR><BR></SPAN>五、选择技巧<SPAN lang=EN-US> <BR></SPAN>用户可以用鼠标一个一个地选择目标,选择的目标逐个地添加到选择集中,另外,<SPAN lang=EN-US>AutoCAD</SPAN>还提供了<SPAN lang=EN-US>Window</SPAN>(以键入<SPAN lang=EN-US>“w”</SPAN>响应<SPAN lang=EN-US>Select object</SPAN>:或直接在屏幕上自右至左拉一个矩形框响应<SPAN lang=EN-US>Select object</SPAN>:提示),<SPAN lang=EN-US>Crossing</SPAN>(以键入<SPAN lang=EN-US>“C”</SPAN>响应<SPAN lang=EN-US>Select object</SPAN>:或直接在屏幕上自左至右拉一个矩形框响应<SPAN lang=EN-US>Select object</SPAN>:提示),<SPAN lang=EN-US>Cpolygon</SPAN>(以键入<SPAN lang=EN-US>“CP”</SPAN>响应<SPAN lang=EN-US>Select object</SPAN>:),<SPAN lang=EN-US>Wpolygon</SPAN>(以键入<SPAN lang=EN-US>“WP”</SPAN>响应<SPAN lang=EN-US>Select object</SPAN>:)等多种窗口方式选择目标,其中<SPAN lang=EN-US>Window</SPAN>及<SPAN lang=EN-US>Crossing</SPAN>用于矩形窗口,而<SPAN lang=EN-US>Wpolygon</SPAN>及<SPAN lang=EN-US>Cpolygon</SPAN>用于多边形窗口,在<SPAN lang=EN-US>Window</SPAN>及<SPAN lang=EN-US>Wpolygon</SPAN>方式下,只有当实体的所有部分都被包含在窗口时,实体才被选中,而在<SPAN lang=EN-US>Crossing</SPAN>及<SPAN lang=EN-US>Cpolygon</SPAN>方式下,只要实体的一部分包括在窗口内,实体就被选择像。<SPAN lang=EN-US>AutoCAD</SPAN>还提供了<SPAN lang=EN-US>Fence</SPAN>方式(以键入<SPAN lang=EN-US>“F”</SPAN>响应<SPAN lang=EN-US>Select object</SPAN>:)选择实体,画出一条不闭合的折线,所有和该折线相交的实体即被选择。在选择目标时,有时会不小心选中不该选择的目标,这时用户可以键入<SPAN lang=EN-US>R</SPAN>来响应<SPAN lang=EN-US>“select objects</SPAN>:<SPAN lang=EN-US>”</SPAN>提示,然后把一些误选的目标从选择集中剔除,然后键入<SPAN lang=EN-US>A</SPAN>,再向选择集中添加目标。当所选择实体和别的实体紧挨在一起时可在按住<SPAN lang=EN-US>CTRL</SPAN>键的同时,然后连续单击鼠标左键,这时紧挨在一起的实体依次高亮度显示,直到所选实体高亮度显示,再按下<SPAN lang=EN-US>enter</SPAN>键(或单击鼠标右键),即选择了该实体。还可以有条件选择实体,即用<SPAN lang=EN-US>'filter</SPAN>响应<SPAN lang=EN-US>select objects</SPAN>:,在<SPAN lang=EN-US>AutoCAD2000</SPAN>中,还提供了<SPAN lang=EN-US>QuickSelect</SPAN>方式选择实体,功能和<SPAN lang=EN-US>filter</SPAN>类似,但操作更简单,方便。<SPAN lang=EN-US>AutoCAD</SPAN>提供的选择集的构造方法功能很强,灵活恰当地使用可使制图的效率大大提高。<SPAN lang=EN-US> <BR><BR></SPAN>六、质量属性查询<SPAN lang=EN-US> <BR>AutoCAD</SPAN>提供点坐标(<SPAN lang=EN-US>ID</SPAN>),距离(<SPAN lang=EN-US>Distance</SPAN>),面积(<SPAN lang=EN-US>area</SPAN>)的查询,给图形的分析带来了很大的方便,但是在实际工作中,有时还须查询实体质量属性特性,<SPAN lang=EN-US>AutoCAD</SPAN>提供实体质量属性查询(<SPAN lang=EN-US>Mass Properties</SPAN>),可以方便查询实体的惯性矩、面积矩、实体的质心等,须注意的是,对于曲线、多义线构造的闭合区域,应先用<SPAN lang=EN-US>region</SPAN>命令将闭合区域面域化,再执行质量属性查询,才可查询实体的惯性矩、面积矩、实体的质心等属性。 </SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体; mso-font-kerning: 0pt"><o:p></o:p></SPAN></P></TD></TR></TBODY></TABLE></DIV>
zjf1206 发表于 2006-5-2 09:59:01
Re: CAD使用六则
还算不错
wjpxbb 发表于 2006-5-2 11:00:02
Re: CAD使用六则
感谢楼主
zjf1206 发表于 2006-5-2 14:53:07
Re: CAD使用六则
bucuo
ailb1992 发表于 2006-5-26 14:00:13
Re: CAD使用六则
恩,谢谢了
waterboy213 发表于 2006-9-3 16:23:53
Re: CAD使用六则
楼主提供的这六则是我们画图中不太常用的,不过写的还是很好,谢谢分享!
mayoulong 发表于 2006-9-9 17:47:55
Re: CAD使用六则
很感谢你,挺好使,谢谢.
tianzumin 发表于 2006-9-22 11:08:45
Re: CAD使用六则
经验之谈,谢谢
wzhif2008 发表于 2006-9-22 11:31:24
Re: CAD使用六则
我的一点心得,在使用CAD时将右键的功能设置一下是比较能提高绘图速度的
试一下!!
szsszs 发表于 2006-9-22 11:43:52
Re: CAD使用六则
真的很不错!!
页: [1] 2 3 4
查看完整版本: CAD使用六则
