金属材料的英文翻译---[求助]
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>MATERIAL SPEC.</FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" /><st1:State w:st="on"><st1:place w:st="on"><SPAN lang=EN-US>AL</SPAN></st1:place></st1:State><SPAN lang=EN-US> ALLOY LM6</SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>SS<st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="440" UnitName="C">440C</st1:chmetcnv> 50-56HRC</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>C.R.S. Zn Plated</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>S.S.#304</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>S.S.#420 50-56HRC</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>PP FDA</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>SILICON FDA 75±5°RIGIDITY</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>PA66+GF FDA</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT size=3><FONT face="Times New Roman">ADHESIVE LABEL, TRANSPARENT54X <st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="10.5" UnitName="mm">10.5MM</st1:chmetcnv></FONT></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT size=3><FONT face="Times New Roman">SILVER POLYESTER LABEL, 50.5 X <st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="25" UnitName="mm">25MM</st1:chmetcnv></FONT></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>M3.0 TAPTITE HARDENED, <st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="7" UnitName="mm">7MM</st1:chmetcnv> L</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>DIA <st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="True" SourceValue="5" UnitName="mm">5.0 MM</st1:chmetcnv>, <st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="True" SourceValue="15" UnitName="l">15 L</st1:chmetcnv> MM,COUNTER SINK, BT TYPE</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><st1:State w:st="on"><st1:place w:st="on"><SPAN lang=EN-US>AL</SPAN></st1:place></st1:State><SPAN lang=EN-US> ALLOY #380/ ADC 12</SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>SS<st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="440" UnitName="C">440C</st1:chmetcnv> 48-52HRC</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>Ni Plated</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>Rubber</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>S.S.#416</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>PA+GF</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>Zn</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>Al</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>STEEL</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>Zn-PTD STEEL</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>SPRING STEEL</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>BLACK OXIDED SPRING STEEL</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>PA+30%</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>Ni-PTD STEEL</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">CR-PTD STEEL</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">Ni-PTD STEEL</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">Cu</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">MUSIC WIRE</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">BLACK OXIDED STEEL</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">STEEL M6X10</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">Cu M4</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">STEEL</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">Ni Plated Steel M3X12</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><st1:City w:st="on"><st1:place w:st="on"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">CORK</SPAN></st1:place></st1:City><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">SILICON</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><st1:State w:st="on"><st1:place w:st="on"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">AL</SPAN></st1:place></st1:State><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt"> 6061</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">CRS Zn PTD</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">PLATED STEEL</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">SPRING STEEL</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt">spring Steel</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 14.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US>PLATED STEEL</SPAN><SPAN lang=EN-US style="mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US>104.5 X 41 X <st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="True" SourceValue=".1" UnitName="mm">0.1 MM</st1:chmetcnv>, 2 COLOR ,White and black</SPAN><SPAN lang=EN-US style="mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt">CRS Zn PTD</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt">Fe</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt">Stainless steel SS3304</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt">Spring Steel</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt">MAGNETIC IRON</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt">SPONGE MAT</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt">Stainless steel</SPAN><SPAN lang=EN-US style="mso-bidi-font-size: 16.0pt; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">POL</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">SILICONE</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">ACETAL</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">ST</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">NYLON</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">PH-15-7 SS</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">COLD ROLLED STEEL</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">FACIES SPRAY-PAINT STEEL</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">SPRING STEEL</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">BL-Zn plated steel</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">S.S.#304 D2XL<st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="20" UnitName="mm">20mm</st1:chmetcnv></SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">Bl-Zn plated steel</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><st1:City w:st="on"><st1:place w:st="on"><SPAN lang=EN-US style="FONT-SIZE: 14pt">CORK</SPAN></st1:place></st1:City><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">ZN PLATED STEELD3.5XL<st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="29.5" UnitName="mm">29.5mm</st1:chmetcnv></SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">NYLON 6 TORAY CM1017</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">ZN Plated steel</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US>VINYL</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">ZN Plated steel D4XL<st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="5.5" UnitName="mm">5.5mm</st1:chmetcnv></SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">STEEL WIRE WITH SLEEVE</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">PLATED STEEL</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">spring Steel</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"><SPAN lang=EN-US style="FONT-SIZE: 14pt">CRS Zn PTD</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US>PLATED STEEL</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体"><o:p></o:p></SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><o:p><FONT face="Times New Roman" size=3> </FONT></o:p></SPAN></P>
Re: 金属材料的英文翻译---[求助]
MATERIAL SPEC.特殊材料AL ALLOY LM6铝合金,型号LM6
SS440C 50-56HRC不锈钢,型号440C,热处理硬度HRC50-56
C.R.S. Zn Plated热轧钢镀锌
S.S.#304不锈钢,型号304
S.S.#420 50-56HRC不锈钢,型号420,热处理硬度HRC50-56
PP FDA
PA66+GF FDA
ADHESIVE LABEL, TRANSPARENT54X 10.5MM
SILVER POLYESTER LABEL, 50.5 X 25MM
M3.0 TAPTITE HARDENED, 7MM L
DIA 5.0 MM, 15 L MM,COUNTER SINK, BT TYPE直径5mm,长15mm,
AL ALLOY #380/ ADC 12
SS440C 48-52HRC
Ni Plated
Rubber
S.S.#416
PA+GF
Zn
Al
STEEL
Zn-PTD STEEL
SPRING STEEL
PA+30%
Al
Ni-PTD STEEL
CR-PTD STEEL
Ni-PTD STEEL
Cu
MUSIC WIRE
BLACK OXIDED STEEL
STEEL M6X10
Cu M4
STEEL
CORK
SILICON
AL 6061
CRS Zn PTD
PLATED STEEL
CRS Zn PTD
PLATED STEEL
SPRING STEEL
spring Steel
CRS Zn PTD
CRS Zn PTD
PLATED STEEL
CRS Zn PTD
PLATED STEEL
104.5 X 41 X 0.1 MM, 2 COLOR ,White and black
CRS Zn PTD
Fe
CRS Zn PTD
Spring Steel
MAGNETIC IRON
SPONGE MAT
CRS Zn PTD
Stainless steel
Spring Steel
POL
SILICONE
ACETAL
ST
NYLON
PH-15-7 SS
COLD ROLLED STEEL
SPRING STEEL
BL-Zn plated steel
S.S.#304 D2XL20mm
Bl-Zn plated steel
CORK
ZN PLATED STEELD3.5XL29.5mm
ZN Plated steel
VINYL
ZN Plated steel
ZN Plated steel D4XL5.5mm
PLATED STEEL
SPRING STEEL
spring Steel
SPRING STEEL
CRS Zn PTD
PLATED STEEL
我先copy下来,下午从工厂回来有时间就帮你弄完。。。Re: 金属材料的英文翻译---[求助]
我也有一些不会的,只是把会的翻译了,然后有一些也不太确定,请找贵司专业人士再确认一下。。然后如果下次再有要翻译的东西,可以先把重复的去掉。。。嘻嘻
MATERIAL SPEC: 材料规格
AL ALLOY LM6: 铝合金 LM6
SS440C 50-56HRC: 不锈钢440 C 硬度为56-56HRC
C.R.S. Zn Plated: 锌板
S.S.#304: 不锈钢304
S.S.#420 50-56HRC: 不锈钢420硬度为56-56HRC
PP FDA
PA66+GF FDA
ADHESIVE LABEL, TRANSPARENT54X 10.5MM: 透明标签 54*10.5毫米
SILVER POLYESTER LABEL, 50.5 X 25MM: 银色聚脂标签。50.5*25毫米
M3.0 TAPTITE HARDENED, 7MM L: M3硬化TAPTITE 7毫米长
DIA 5.0 MM, 15 L MM,COUNTER SINK, BT TYPE: 直径5毫米,15毫米长COUNTER SINK(多种译法),按种类
AL ALLOY #380/ ADC 12:铝合金#380/ ADC12
SS440C 48-52HRC 不锈钢440 C 硬度为48-52HRC
Ni Plated 镀镍板
Rubber: 橡胶
S.S.#416 :不锈钢416
PA+GF:
Zn: 锌
Al: 铝
STEEL:钢
Zn-PTD STEEL:镀锌钢
SPRING STEEL:弹簧钢
BLACK OXIDED SPRING STEEL:黑色氧化弹簧钢
PA+30%:镁?
Al: 铝
Ni-PTD STEEL:镀镍板
CR-PTD STEEL:镀铬板
Ni-PTD STEEL:镀镍板
Cu:铜
MUSIC WIRE:琴用钢丝
BLACK OXIDED STEEL黑色氧化钢
STEEL M6X10:M6X10钢
Cu M4:M4 铜
STEEL:钢
Ni Plated Steel M3X12:M3X12镀镍钢
CORK:塞子
SILICON:硅
AL 6061:6061铝
CRS Zn PTD:CRS镀锌的?
PLATED STEEL:镀。。钢
CRS Zn PTD:CRS镀锌?
PLATED STEEL:镀。。钢
SPRING STEEL:弹簧钢
spring Steel:弹簧钢
CRS Zn PTD:CRS镀锌?
PLATED STEEL:镀。。钢
104.5 X 41 X 0.1 MM, 2 COLOR ,White and black:104.5 X 41 X 0.1 毫米,黑白两种颜色
Fe:铁
Stainless steel SS3304:不锈钢3304(多了一个3吧)
MAGNETIC IRON:磁铁
SPONGE MAT:海绵垫
Stainless steel:不锈钢
POL
SILICONE:硅树脂
ACETAL:乙缩醛
ST:多种译法,请参照图纸或实际情况译
NYLON:尼龙
PH-15-7 SS:不锈钢 ph15-7
COLD ROLLED STEEL: 冷轧钢
FACIES SPRAY-PAINT STEEL:彩涂钢?不太确定
SPRING STEEL:弹簧钢
BL-Zn plated steel:BL?镀锌钢
S.S.#304 D2XL20mm:不锈钢304 D2XL20毫米
ZN PLATED STEELD3.5XL29.5mm:镀锌钢D3.5XL29.5毫米
FACIES SPRAY-PAINT STEEL彩涂钢?不太确定
ZN Plated steel:镀锌钢
VINYL:乙烯基
ZN Plated steel:镀锌钢
ZN Plated steel D4XL5.5mm:镀锌钢D4XL5.5mm
STEEL WIRE WITH SLEEVE带套钢丝?
PLATED STEEL:镀。。钢
SPRING STEEL:弹簧钢
spring Steel:弹簧钢
SPRING STEEL:弹簧钢
CRS Zn PTD
PLATED STEEL:镀。。钢
偶翻译完了,居然没有人来看。。。楼主难道不回来看看自己发过的帖子吗?呜呜。。。Re: 金属材料的英文翻译---[求助]
julia-cssc ,好样的!Re: 金属材料的英文翻译---[求助]
蓝色童话。。谢谢!得到肯定好高兴!
素素,不错,看来需要翻译的话就找你了。Re: 金属材料的英文翻译---[求助]
PP FDA 是不是指FDA认证的PP树脂?Re: 金属材料的英文翻译---[求助]
谢谢素素了,偶也用上了,吼吼
