旋转发动机---[讨论]
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">本人是</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">200610077635.7《</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">往复式四冲程内燃机摆动叶片式换气装置》的申请者。现有一个旋转发动机专利要申请。发动机的特点有:</SPAN></FONT></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore"><FONT face="Times New Roman"><FONT size=3>1、</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN></FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>采用旋转活塞,由作功介质直接推动轴而输出扭矩;</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore"><FONT face="Times New Roman"><FONT size=3>2、</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN></FONT></SPAN></SPAN><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">采用进气压缩、预燃、作功排气三个定时连通的容腔来完成热力循环,实现膨胀容积大于压缩容积,提高效率,</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">PV</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">图如下:</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 21pt"><SPAN lang=EN-US><?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 coordsize="21600,21600" o:spt="75" o:preferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><v:path o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"></v:path><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:lock v:ext="edit" aspectratio="t"></o:lock></v:shapetype><v:shape id=_x0000_i1025 style="WIDTH: 414.75pt; HEIGHT: 237pt" type="#_x0000_t75"><v:imagedata src="file:///C:\DOCUME~1\new\LOCALS~1\Temp\msohtml1\01\clip_image001.wmz" o:title="PV"><FONT size=3></FONT></v:imagedata></v:shape></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore"><FONT face="Times New Roman"><FONT size=3>3、</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN></FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>采用对称结构,作功介质的径向力相互平衡,轴的受力状况接近电动机,结构比往复式放大镜简单,材料也少;</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore"><FONT face="Times New Roman"><FONT size=3>4、</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN></FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>用进排气口结构,省去了往复式的进排气阀,噪音也降低了许多;</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore"><FONT face="Times New Roman"><FONT size=3>5、</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN></FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>燃料可采用催化桶形燃烧,燃烧完全,排放好;</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore"><FONT face="Times New Roman"><FONT size=3>6、</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN></FONT></SPAN></SPAN><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">可变进气量、可变余隙容积,在发动机的各种工况,保证压缩终点的温度在最佳点上,发动机的运行经济性提高了,排气的</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">NO<SUB>X</SUB></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">也少了;</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore"><FONT face="Times New Roman"><FONT size=3>7、</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN></FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>功率大的发动机可采用中空轴、加上离合器由两台以上的小功率发动机组成,根据工况可选择部分或全部发动机运行,提高了发动机可靠性与经济性,也可用于需要正反转都要输出扭矩的场合(如同轴双螺旋浆);</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore"><FONT face="Times New Roman"><FONT size=3>8、</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN></FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>该结构用于热气机、压缩机也是种很好的结构。</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>鉴于有以上优点,该发动机若能在社会中推广使用,将带来巨大的经济与社会价值。而我国的发动机行业又落后于发达国家几十年,也不知道现在研发周期需要多长时间。在选折保密与提前公开上犯愁。请大家发表建议,谢谢!</FONT></SPAN></P>
Re: 旋转发动机
本人是从事汽车发动机的设计工作,不知道楼主设计的发动机可否用于汽车上面,目前我国的发动机确实落后欧洲,日本等国几十年,但是我们相信有楼主这样的人才和我们国内专业的共同努力,我们国家的发动机一定会赶上西方国家的!!Re: 旋转发动机---[讨论]
本人也认识到我国发动机的落后,在不工作全力完成总的技术方案的设计后,就交给了711研究所与国内几个大的发动机厂家。由于密封问题不能达到往复式的性能,在汽油机上应用最好,可采用催化点燃或蓄热点燃,比火花塞可靠。Re: 旋转发动机---[讨论]
楼主的设想好像与汪克尔发动机相似,汪克尔发动机现在已经退出了历史舞台,主要原因就是密封和热效率。我认为我国发动机的落后,主要是材质与工艺,其次是国人的意识。什么电喷、电控、共轨燃油喷射我想对楼主和复音锰师傅来讲恐怕不是什么秘密。我们都知道燃油喷射压力越高,雾化越好,效率就越高,但是,要实现500MPa的喷射压力,咱们用什么材料做,又怎么加工?我国引进的轿车发动机技术不是很落后,但是只要一国产化,寿命缩短了,效率降低了,噪音增大了,几乎所有的问题都出现了。楼主设计的发动机如果仅仅是在结构和技术上创新,不考虑材料与工艺,目标恐怕很难实现。至于研发周期,我觉得至少3~5年,结构设计、强度校核都不是问题,关键是可靠性试验。Re: 旋转发动机---[讨论]
<P>楼主的设想好像与汪克尔发动机相似,汪克尔发动机现在已经退出了历史舞台,主要原因就是密封和热效率。quote]</P><P> <FONT size=5>是的,主要原因就是密封、热效率和寿命问题。</FONT></P>
<P><FONT size=5>结构决定性质:径向密封片与缸体间始终是线接触,密封效果远不如面接触的活塞环与汽缸的密封;</FONT></P>
<P><FONT size=5>线接触也不如面接触耐磨。这就是为什么汪克尔发动机的动力性、经济性差的原因。要抓住事物的本质,从根本上解决问题!</FONT></P>
Re: 旋转发动机---[讨论]
本发动机与三角转子完全不同,大部分工作时间可以做到面密封。在军用上有前景,主要是单位功率重量体积小。申请递交了五个月了,初审通过,没有收到提前公开通知。资料有寄给711研究所、玉柴、奇瑞等。本人还有一个的技术方案可以提高发动机的性能。Re: 旋转发动机---[讨论]
这本书有没有完整的资料?请发:<A href="mailto:killjpan@126.com">killjpan@126.com</A>Re: 旋转发动机---[讨论]
做了个视频,不太好! 视频做的真棒!不知能否也帮俺的旋转发动机做个视频。 下来看看先,谢谢。大家讨论
