潘玉洪42 发表于 2010-12-4 08:12:44
熔模铸件,求助译成英文
熔模铸件常见缺陷分析及处理——表面缺陷类之一 化学粘砂与机械粘砂 摘要:机械粘砂和化学粘砂是熔模铸件常见的铸造缺陷之一,它是指在铸件的表面上牢固地粘结着一层金属与型壳材料结合物。本文重点阐述熔模铸件化学粘砂和机械粘砂的外部特征,产生的部位、机理以及主要原因,同时提出了从熔模铸造的选材、制壳工艺、焙烧工艺、熔炼工艺等方面采取实用、有效的对策,从而提高熔模铸件的合格率。关键词:熔模铸件;
粘砂缺陷;
分析与处理 摘要: 本文重点阐述了熔模铸件鼠尾、凹陷和夹砂的外部特征,产生的部位,产生缺陷的两种机理;分析了产生缺陷的两种主要原因;同时提出了应采取的相应对策,即降低型壳在焙烧或浇注时产生的热应力,提高型壳质量避免分层;以便减少熔模铸件的鼠尾、凹陷和夹砂缺陷。关键词:熔模铸件;鼠尾、凹陷、夹砂;缺陷分析与处理
帅气流氓 发表于 2010-12-4 08:45:29
The melt mold casting common flaw analyzes and processes
-- surface defects class of
<dnt> the </dnt> chemistry fat sand and mechanical fat sand
<dnt> the </dnt> abstract: The mechanical fat sand and chemistry fat sand melt one of mold casting common casting defects, it is refers to the casting surface is caking a metal reliably and the shell material union. This article key elaboration melt mold casting chemistry fat sand and the mechanical fat sand's exterior characteristic, produces the spot, the mechanism as well as the primary cause, simultaneously proposed from melt mold aspects and so on casting's selection, system shell craft, roasting craft, smelting craft takes, the effective countermeasure practical, thus enhancement melt mold casting qualified rate.
key word: Melt mold casting;
Mouse tail, hollow, sand inclusion; Flaw analysis and processing
潘玉洪42 发表于 2010-12-4 09:44:01
回复 liumanghl 的帖子
我看不懂英文,是你为我翻译的吗?请告知。谢谢!
帅气流氓 发表于 2010-12-4 10:02:34
是的师父你那里的呢我上海的
潘玉洪42 发表于 2010-12-4 10:04:23
回复 liumanghl 的帖子
我是深圳的。谢谢你!
潘玉洪42 发表于 2010-12-4 10:07:45
回复 liumanghl 的帖子
你可否告诉我:你的电话(手机或座机)、邮箱,以便联系?
This article elaborated with emphasis melt mold casting mouse tail, hollow and sand inclusion exterior characteristic, produces the spot, produces the flaw two kind of mechanisms; Analyzed has had the flaw two kind of primary causes; Simultaneously proposed should adopt the corresponding countermeasure, namely reduces the shell when the roasting or the casting produces the thermal load, enhances the chitin quantity to avoid the lamination; In order to reduce the melt mold casting the mouse tail, hollow and the sand inclusion flaw.             key word: Melt mold casting;
Mouse tail, hollow, sand inclusion; Flaw analysis and processing   刚刚漏了一句 这样 才是全部的 不好意思 13818880924 xhliu1988@hotmail.com
帅气流氓 发表于 2010-12-4 10:18:36
早上 在 翻译一半就开会 去 了 就直接回复了   上面 才是 全部的 小生不才有不到的地方还请 社区的朋友帮忙指点
潘玉洪42 发表于 2010-12-4 11:16:56
回复 liumanghl 的帖子
谢谢你!真诚地谢谢你!充分显示社区的作用。
冷水黄金 发表于 2010-12-4 21:32:50
顶那位热心少侠呀。
顶潘老又产了
查看完整版本: 熔模铸件,求助译成英文
