浅谈齿轮渗碳淬火有效硬化层及硬度梯度
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center" align=center><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-SIZE: 22pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">浅谈齿轮渗碳淬火有效硬化层及硬度梯度</SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US style="FONT-SIZE: 22pt"><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></B></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center" align=center><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US style="FONT-SIZE: 22pt"><o:p><FONT face="Times New Roman"> </FONT></o:p></SPAN></B></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 28pt; mso-char-indent-count: 2.0"><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">随着机械工业的发展,对齿轮的质量要求日益提高,而齿轮的强度寿命和制造精度与热处理质量有很大关系。为了检验齿轮材料热处理质量,在</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><FONT face="Times New Roman">1987</FONT></SPAN><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">年以前,我国的齿轮渗碳淬火内在质量检验标准多为终态金相检验标准。由于检测仪器的精度、分辨率等因素以及检验人员的经验参差不齐,造成检验结果有很大差异和争议。为了解决金相法内在检验存在的弊端,机械部在</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><FONT face="Times New Roman">1987</FONT></SPAN><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">年借鉴了</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><FONT face="Times New Roman">DIN.ISO</FONT></SPAN><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">等标准中有关内容,修订了我国现行齿轮渗碳淬火内在质量检验标准。此检验标准中,其金相组织检验标准基本与原标准相似,主要是对渗碳层深度及碳浓度梯度的测定作了较大的修改。下面就渗碳层深度和碳浓度梯度分别采用金相法与硬度法测定进行简述。</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 48pt"><SPAN lang=EN-US style="FONT-SIZE: 12pt"><o:p><FONT face="Times New Roman"> </FONT></o:p></SPAN></P>
<P> </P>
Re: 浅谈齿轮渗碳淬火有效硬化层及硬度梯度
很好,谢楼主Re: 浅谈齿轮渗碳淬火有效硬化层及硬度梯度
很好的资料,楼主辛苦了!Re: 浅谈齿轮渗碳淬火有效硬化层及硬度梯度
请问楼主,表面碳浓度是用什么方法检验的,是否可提供一些这方面的资料啊,先谢谢了啊谢谢
谢谢楼主!不知道有没轴承方面的渗碳有效硬化层梯度标准啊 这个好啊
