王树大 发表于 2010-9-4 21:20:17
现在的28-36V锂电池充电钻扭矩已经足够大,视频当然是夸张手法
http://player.youku.com/player.php/sid/XMjAzODE0OTI0/v.swf
目前美国市场上扭矩第二大的充电钻,28V锂电池的Product Description
The Milwaukee 0724 Cordless 28-volt 1/2 in. Hammer-Drill uses the Milwaukee built high power motor to develop an enormous 600 in. lbs. of maximum torque and 0-600/0-1800 rpm, ideal for drilling larger holes and driving larger screws faster! Powering the 0724 is the revolutionary 28-volt Lithium-Ion battery pack exclusively from Milwaukee. The 28-volt battery pack weighs less than an 18-volt pack yet delivers two times the run-time, making this the ideal solution for all drilling and driving needs! Only the Milwaukee battery can be inserted in the reverse position which allows for the ultimate balance when working overhead or in hard to reach areas. The 0724 comes standard with the industry's tightest gripping chuck: a 1/2-inch all-metal, single-sleeve, ratcheting chuck with all carbide jaws that keeps bits from falling out and drill bits from slipping! A comfortable non-slip, soft-grip handle reduces vibration and fatigue. The 0724 also comes standard with the patented Clip-Lok System. The Clip-Lok???? System attaches securely to the operator's belt or tool bags and easily releases with one hand, ideal for when working from a ladder or when there is nowhere to place the tool when adjusting or positioning a work piece. The Clip-Lok System also features an on-board bit holder which holds up to two standard Phillips bits. Includes two 28V batteries, 1-hour charger, carrying case, Clip-Lok System, side handle and #2 Phillips bit.
Product Details[*]Amazon Sales Rank: #2022 in Home Improvement[*]Color: NA[*]Brand: Milwaukee[*]Model: 0724-24[*]Number of items: 1[*]Dimensions: 17.20 poundsFeatures[*]1/2-inch 28-volt lithium-ion cordless hammer drill/driver kit[*]600-pounds of torque; up to twice the run-time of 18-volt tools[*]All-metal single-sleeve ratcheting chuck with all carbide jaws; rugged plastic housing[*]Includes hammer drill/driver, 2 batteries, 1-hour charger, case, belt clip-lock system, side handle, Phillips bit[*]10-1/2-inches; 6.7-pounds; 5-year warranty
王树大 发表于 2010-9-4 21:23:42
这个机器我有2把,钻速还是很高的。我的机器挺新的,碳刷火花确实大了点,磨合一段时间后会好些的
craftsman 发表于 2010-9-5 05:48:30
关键是要多少钱呢,太吓人了个头小点不变成螺旋桨了
gdb341 发表于 2010-9-8 22:38:04
路过。。。顺便顶一下。。。。
603107044 发表于 2010-9-8 22:57:00
如果真这样就不是要不要钱的问题了
关键是要命
呵呵
查看完整版本: 现在的28-36V锂电池充电钻扭矩已经足够大,视频当然是夸张手法
