钢铁知识大全---搞机械的人士必须的知识
<TABLE class=MsoNormalTable style="mso-cellspacing: 0cm; mso-table-lspace: 2.25pt; mso-table-rspace: 2.25pt; mso-table-anchor-vertical: paragraph; mso-table-anchor-horizontal: column; mso-table-left: right; mso-table-top: middle; mso-padding-alt: 7.5pt 7.5pt 7.5pt 7.5pt" cellSpacing=0 cellPadding=0 align=right border=0><TBODY>
<TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes; mso-yfti-lastrow: yes">
<TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 7.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 7.5pt; PADDING-BOTTOM: 7.5pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 7.5pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 11.25pt; TEXT-ALIGN: left; mso-pagination: widow-orphan; mso-element: frame; mso-element-frame-hspace: 2.25pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: right; mso-element-top: middle; mso-height-rule: exactly" align=left><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: 宋体; mso-bidi-font-family: 宋体; mso-font-kerning: 0pt"><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p> </o:p></SPAN></P></TD></TR></TBODY></TABLE><STRONG>钢铁知识大全---搞机械的人士必须的知识(转载文章)<BR></STRONG>
<TABLE cellSpacing=0 cellPadding=10 align=right border=0>
<TBODY>
<TR>
<TD><STRONG></STRONG></TD></TR></TBODY></TABLE>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt">钢铁知识大全<BR><BR>钢铁知识大全<FONT face="Times New Roman">(1)<BR></FONT>钢材机械性能介绍<BR><FONT face="Times New Roman">1.</FONT>屈服点(<FONT face="Times New Roman">σs</FONT>)<BR>钢材或试样在拉伸时,当应力超过弹性极限,即使应力不再增加,而钢材或试样仍继续发生明显的塑性变形,称此现象为屈服,而产生屈服现象时的最小应力值即为屈服点。<FONT face="Times New Roman"> <BR></FONT>设<FONT face="Times New Roman">Ps</FONT>为屈服点<FONT face="Times New Roman">s</FONT>处的外力,<FONT face="Times New Roman">Fo</FONT>为试样断面积,则屈服点<FONT face="Times New Roman">σs =Ps/Fo(MPa)</FONT>,<FONT face="Times New Roman">MPa</FONT>称为兆帕等于<FONT face="Times New Roman">N</FONT>(牛顿)<FONT face="Times New Roman">/mm2</FONT>,(<FONT face="Times New Roman">MPa=106Pa</FONT>,<FONT face="Times New Roman">Pa</FONT>:帕斯卡<FONT face="Times New Roman">=N/m2</FONT>)<BR><FONT face="Times New Roman">2.</FONT>屈服强度(<FONT face="Times New Roman">σ0.2</FONT>)<BR>有的金属材料的屈服点极不明显,在测量上有困难,因此为了衡量材料的屈服特性,规定产生永久残余塑性变形等于一定值(一般为原长度的<FONT face="Times New Roman">0.2%</FONT>)时的应力,称为条件屈服强度或简称屈服强度<FONT face="Times New Roman">σ0.2 </FONT>。<BR><FONT face="Times New Roman">3.</FONT>抗拉强度(<FONT face="Times New Roman">σb</FONT>)<BR>材料在拉伸过程中,从开始到发生断裂时所达到的最大应力值。它表示钢材抵抗断裂的能力大小。与抗拉强度相应的还有抗压强度、抗弯强度等。<BR>设<FONT face="Times New Roman">Pb</FONT>为材料被拉断前达到的最大拉力,<FONT face="Times New Roman">Fo</FONT>为试样截面面积,则抗拉强度<FONT face="Times New Roman">σb= Pb/Fo </FONT>(<FONT face="Times New Roman">MPa</FONT>)。<BR><FONT face="Times New Roman">4.</FONT>伸长率(<FONT face="Times New Roman">δs</FONT>)<BR>材料在拉断后,其塑性伸长的长度与原试样长度的百分比叫伸长率或延伸率。<BR><FONT face="Times New Roman">5.</FONT>屈强比(<FONT face="Times New Roman">σs/σb</FONT>)<BR>钢材的屈服点(屈服强度)与抗拉强度的比值,称为屈强比。屈强比越大,结构零件的可靠性越高,一般碳素钢屈强比为<FONT face="Times New Roman">0.6-0.65</FONT>,低合金结构钢为<FONT face="Times New Roman">0.65-0.75</FONT>合金结构钢为<FONT face="Times New Roman">0.84-0.86</FONT>。<BR><FONT face="Times New Roman">6.</FONT>硬度<BR>硬度表示材料抵抗硬物体压入其表面的能力。它是金属材料的重要性能指标之一。一般硬度越高,耐磨性越好。常用的硬度指标有布氏硬度、洛氏硬度和维氏硬度。<BR>⑴布氏硬度(<FONT face="Times New Roman">HB</FONT>)<BR>以一定的载荷(一般<FONT face="Times New Roman">3000kg</FONT>)把一定大小(直径一般为<FONT face="Times New Roman">10mm</FONT>)的淬硬钢球压入材料表面,保持一段时间,去载后,负荷与其压痕面积之比值,即为布氏硬度值(<FONT face="Times New Roman">HB</FONT>),单位为公斤力<FONT face="Times New Roman">/mm2 (N/mm2)</FONT>。<BR>⑵洛氏硬度(<FONT face="Times New Roman">HR</FONT>)<BR>当<FONT face="Times New Roman">HB>450</FONT>或者试样过小时,不能采用布氏硬度试验而改用洛氏硬度计量。它是用一个支持角<FONT face="Times New Roman">120°</FONT>的金刚石圆锥体或直径为<FONT face="Times New Roman">1.59</FONT>、<FONT face="Times New Roman">3.18mm</FONT>的钢球,在一定载荷下压入被测材料表面,由压痕的深度求出材料的硬度。根据试验材料硬度的不同,分三种不同的标度来表示:<BR><FONT face="Times New Roman">HRA</FONT>:是采用<FONT face="Times New Roman">60kg</FONT>载荷和钻石锥压入器求得的硬度,用于硬度极高的材料(如硬质合金等)。<BR><FONT face="Times New Roman">HRB</FONT>:是采用<FONT face="Times New Roman">100kg</FONT>载荷和直径<FONT face="Times New Roman">1.58mm</FONT>淬硬的钢球,求得的硬度,用于硬度较低的材料(如退火钢、铸铁等)。<BR><FONT face="Times New Roman">HRC</FONT>:是采用<FONT face="Times New Roman">150kg</FONT>载荷和钻石锥压入器求得的硬度,用于硬度很高的材料(如淬火钢等)。<BR>⑶维氏硬度(<FONT face="Times New Roman">HV</FONT>)<BR>以<FONT face="Times New Roman">120kg</FONT>以内的载荷和支持角为<FONT face="Times New Roman">136°</FONT>的金刚石方形锥压入器压入材料表面,用材料压痕凹坑的表面积除以载荷值,即为维氏硬度值(<FONT face="Times New Roman">HV</FONT>)<BR>钢材商品知识(一)<FONT face="Times New Roman">----</FONT>钢的分类<BR>第一节<FONT face="Times New Roman"> </FONT>钢的分类<BR>一、黑色金属和有色金属<BR><FONT face="Times New Roman">1</FONT>、黑色金属<BR>是指铁和铁的合金。如钢、生铁、铁合金、铸铁等。钢和生铁都是以铁为基础,以碳为主要添加元素的合金,统称为铁碳合金。<BR>生铁是指把铁矿石放到高炉中冶炼而成的产品,主要用来炼钢和制造铸件。<BR>把铸造生铁放在熔铁炉中熔炼,即得到铸铁(液状<FONT face="Times New Roman">,</FONT>含碳量大于<FONT face="Times New Roman">2.11%</FONT>的铁碳合金),把液状铸铁浇铸成铸件,这种铸铁叫铸铁件。<BR>铁合金是由铁与硅、锰、铬、钛等元素组成的合金,铁合金是炼钢的原料之一,在炼钢时做钢的脱氧剂和合金元素添加剂用。<BR>含碳量低于<FONT face="Times New Roman">2.11%</FONT>的铁碳合金称为钢,把炼钢用生铁放到炼钢炉内按一定工艺熔炼,即得到钢。钢的产品有钢锭、连铸坯和直接铸成各种钢铸件等。通常所讲的钢,一般是指轧制成各种钢材的钢。<FONT face="Times New Roman"> <BR>2</FONT>、有色金属<BR>又称非铁金属,指除黑色金属外的金属和合金,如铜、锡、铅、锌、铝以及黄铜、青铜、铝合金和轴承合金等。另外在工业上还采用铬、镍、锰、钼、钴、钒、钨、钛等,这些金属主要用作合金附加物,以改善金属的性能,其中钨、钛、钼等多用以生产刀具用的硬质合金。以上这些有色金属都称为工业用金属,此外还有贵重金属:铂、金、银等和稀有金属,包括放射性的铀、镭等。<BR>二、钢的分类<BR>钢的主要元素除铁、碳外,还有硅、锰、硫、磷等。钢的分类方法多种多样,其主要方法有如下七种:<BR><FONT face="Times New Roman">1</FONT>、按品质分类<BR><FONT face="Times New Roman">(1) </FONT>普通钢(<FONT face="Times New Roman">P≤0.045%</FONT>,<FONT face="Times New Roman">S≤0.050%</FONT>)<BR><FONT face="Times New Roman">(2) </FONT>优质钢(<FONT face="Times New Roman">P</FONT>、<FONT face="Times New Roman">S</FONT>均<FONT face="Times New Roman">≤0.035%</FONT>)<BR><FONT face="Times New Roman">(3) </FONT>高级优质钢(<FONT face="Times New Roman">P≤0.035%</FONT>,<FONT face="Times New Roman">S≤0.030%</FONT>)<BR><FONT face="Times New Roman">2</FONT>、按化学成份分类<BR><FONT face="Times New Roman">(1) </FONT>碳素钢:<BR><FONT face="Times New Roman">a.</FONT>低碳钢(<FONT face="Times New Roman">C≤0.25%</FONT>);<FONT face="Times New Roman">b.</FONT>中碳钢(<FONT face="Times New Roman">C≤0.25</FONT>~<FONT face="Times New Roman">0.60%</FONT>);<FONT face="Times New Roman">c.</FONT>高碳钢(<FONT face="Times New Roman">C≤0.60%</FONT>)。<BR><FONT face="Times New Roman">(2) </FONT>合金钢:<BR><FONT face="Times New Roman">a.</FONT>低合金钢(合金元素总含量<FONT face="Times New Roman">≤5%</FONT>);<FONT face="Times New Roman">b.</FONT>中合金钢(合金元素总含量><FONT face="Times New Roman">5</FONT>~<FONT face="Times New Roman">10%</FONT>);<FONT face="Times New Roman">c.</FONT>高合金钢(合金元素总含量><FONT face="Times New Roman">10%</FONT>)。<BR><FONT face="Times New Roman">3</FONT>、按成形方法分类:<BR><FONT face="Times New Roman">(1) </FONT>锻钢;<FONT face="Times New Roman">(2) </FONT>铸钢;<FONT face="Times New Roman">(3) </FONT>热轧钢;<FONT face="Times New Roman">(4) </FONT>冷拉钢。<BR><FONT face="Times New Roman">4</FONT>、按金相组织分类<BR><FONT face="Times New Roman">(1) </FONT>退火状态的:<FONT face="Times New Roman">a.</FONT>亚共析钢(铁素体<FONT face="Times New Roman">+</FONT>珠光体);<FONT face="Times New Roman">b.</FONT>共析钢(珠光体);<FONT face="Times New Roman">c.</FONT>过共析钢(珠光体<FONT face="Times New Roman">+</FONT>渗碳体);<FONT face="Times New Roman">d.</FONT>莱氏体钢(珠光体<FONT face="Times New Roman">+</FONT>渗碳体)。<FONT face="Times New Roman"> <BR>(2) </FONT>正火状态的:<FONT face="Times New Roman">a.</FONT>珠光体钢;<FONT face="Times New Roman">b.</FONT>贝氏体钢;<FONT face="Times New Roman">c.</FONT>马氏体钢;<FONT face="Times New Roman">d.</FONT>奥氏体钢。<FONT face="Times New Roman"> <BR>(3) </FONT>无相变或部分发生相变的<BR><FONT face="Times New Roman">5</FONT>、按用途分类<BR><FONT face="Times New Roman">(1) </FONT>建筑及工程用钢:<FONT face="Times New Roman">a.</FONT>普通碳素结构钢;<FONT face="Times New Roman">b.</FONT>低合金结构钢;<FONT face="Times New Roman">c.</FONT>钢筋钢。<BR><FONT face="Times New Roman">(2) </FONT>结构钢<BR><FONT face="Times New Roman">a.</FONT>机械制造用钢:<FONT face="Times New Roman">(a)</FONT>调质结构钢;<FONT face="Times New Roman">(b)</FONT>表面硬化结构钢:包括渗碳钢、渗氨钢、表面淬火用钢;<FONT face="Times New Roman">(c)</FONT>易切结构钢;<FONT face="Times New Roman">(d)</FONT>冷塑性成形用钢:包括冷冲压用钢、冷镦用钢。<BR><FONT face="Times New Roman">b.</FONT>弹簧钢<BR><FONT face="Times New Roman">c.</FONT>轴承钢<BR><FONT face="Times New Roman">(3) </FONT>工具钢:<FONT face="Times New Roman">a.</FONT>碳素工具钢;<FONT face="Times New Roman">b.</FONT>合金工具钢;<FONT face="Times New Roman">c.</FONT>高速工具钢。<BR><FONT face="Times New Roman">(4) </FONT>特殊性能钢:<FONT face="Times New Roman">a.</FONT>不锈耐酸钢;<FONT face="Times New Roman">b.</FONT>耐热钢:包括抗氧化钢、热强钢、气阀钢;<FONT face="Times New Roman">c.</FONT>电热合金钢;<FONT face="Times New Roman">d.</FONT>耐磨钢;<FONT face="Times New Roman">e.</FONT>低温用钢;<FONT face="Times New Roman">f.</FONT>电工用钢。<BR><FONT face="Times New Roman">(5) </FONT>专业用钢——如桥梁用钢、船舶用钢、锅炉用钢、压力容器用钢、农机用钢等。<BR><FONT face="Times New Roman">6</FONT>、综合分类<BR><FONT face="Times New Roman">(1)</FONT>普通钢<BR><FONT face="Times New Roman">a.</FONT>碳素结构钢:<FONT face="Times New Roman">(a) Q195</FONT>;<FONT face="Times New Roman">(b) Q215(A</FONT>、<FONT face="Times New Roman">B)</FONT>;<FONT face="Times New Roman">(c) Q235(A</FONT>、<FONT face="Times New Roman">B</FONT>、<FONT face="Times New Roman">C)</FONT>;<FONT face="Times New Roman">(d) Q255(A</FONT>、<FONT face="Times New Roman">B)</FONT>;<FONT face="Times New Roman">(e) Q275</FONT>。<BR><FONT face="Times New Roman">b.</FONT>低合金结构钢<BR><FONT face="Times New Roman">c.</FONT>特定用途的普通结构钢<BR><FONT face="Times New Roman">(2)</FONT>优质钢(包括高级优质钢)<BR><FONT face="Times New Roman">a.</FONT>结构钢:<FONT face="Times New Roman">(a)</FONT>优质碳素结构钢;<FONT face="Times New Roman">(b)</FONT>合金结构钢;<FONT face="Times New Roman">(c)</FONT>弹簧钢;<FONT face="Times New Roman">(d)</FONT>易切钢;<FONT face="Times New Roman">(e)</FONT>轴承钢;<FONT face="Times New Roman">(f)</FONT>特定用途优质结构钢。<BR><FONT face="Times New Roman">b.</FONT>工具钢:<FONT face="Times New Roman">(a)</FONT>碳素工具钢;<FONT face="Times New Roman">(b)</FONT>合金工具钢;<FONT face="Times New Roman">(c)</FONT>高速工具钢。<BR><FONT face="Times New Roman">c.</FONT>特殊性能钢:<FONT face="Times New Roman">(a)</FONT>不锈耐酸钢;<FONT face="Times New Roman">(b)</FONT>耐热钢;<FONT face="Times New Roman">(c)</FONT>电热合金钢;<FONT face="Times New Roman">(d)</FONT>电工用钢;<FONT face="Times New Roman">(e)</FONT>高锰耐磨钢。<BR><FONT face="Times New Roman">7</FONT>、按冶炼方法分类<BR><FONT face="Times New Roman">(1) </FONT>按炉种分<BR><FONT face="Times New Roman">a.</FONT>转炉钢:<FONT face="Times New Roman">(a)</FONT>酸性转炉钢;<FONT face="Times New Roman">(b)</FONT>碱性转炉钢。或<FONT face="Times New Roman"> (a)</FONT>底吹转炉钢;<FONT face="Times New Roman">(b)</FONT>侧吹转炉钢;<FONT face="Times New Roman">(c)</FONT>支持吹转炉钢。<BR><FONT face="Times New Roman">b. </FONT>电炉钢:<FONT face="Times New Roman">(a)</FONT>电弧炉钢;<FONT face="Times New Roman">(b)</FONT>电渣炉钢;<FONT face="Times New Roman">(c)</FONT>感应炉钢;<FONT face="Times New Roman">(d)</FONT>真空自耗炉钢;<FONT face="Times New Roman">(e)</FONT>电子束炉钢。<BR><FONT face="Times New Roman">(2)</FONT>按脱氧程度和浇注制度分<BR><FONT face="Times New Roman">a.</FONT>沸腾钢;<FONT face="Times New Roman">b.</FONT>半镇静钢;<FONT face="Times New Roman">c.</FONT>镇静钢;<FONT face="Times New Roman">d.</FONT>特殊镇静钢。</P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"> </P>
<P>钢铁知识大全(2)<BR><BR>第二节 我国钢号表示方法<BR>一、我国钢号表示方法概述<BR>钢的牌号简称钢号,是对每一种具体钢产品所取的名称,是人们了解钢的一种共同语言。我国的钢号表示方法,根据国家标准《钢铁产品牌号表示方法》(GB/T221—2000)中规定,并于2000年11月1日开始实施。<BR>产品牌号的表示,一般采用采用汉语拼音字母、化学元素符号和阿拉伯数字相结合的方法表示。即:<BR>①钢号中化学元素采用国际化学符号表示,例如Si,Mn,Cr……等。混合稀土元素用“RE”(或“Xt”)表示。<BR>②产品名称、用途、冶炼和浇注方法等,一般采用汉语拼音的缩写字母表示,<BR>③钢中主要化学元素含量(%)采用阿拉伯数字表示。<BR>采用汉语拼音字母表示产品名称、用途、特性和工艺方法时,一般从代表产品名称的汉 语拼音中选取第一个字母。当和另一个产品所选用的字母重复时,可改用第二个字母或第三个字母,或同时选取两个汉字中的第一个拼音字母。<BR>暂时没有可采用的汉字及汉语拼音的,采用符号为英文字母。<BR>二、我国钢号表示方法的分类说明<BR>1、碳素结构钢和低合金高强度结构牌号表示方法<BR>以上用钢通常分为通用钢和专用钢两大类。牌号表示方法,由钢的屈服点或屈服强度的汉语拼音字母、屈服点或屈服强度数值,钢的质量等级等部分组成,还有的钢加脱氧程度,实际是4个部分组成。 <BR>①通用结构钢采用代表屈服点的拼音字母“Q”。屈服点数值(单位为MPa)和表1中规定的质量等级(A、B、C、D、E)、脱氧方法(F、b、Z、TZ)等符号,按顺序组成牌号。例如:碳素结构钢牌号表示为:Q235AF,Q235BZ;低合金高强度结构钢牌号表示为:Q345C,Q345D。<BR>Q235BZ表示屈服点值≥235MPa、质量等级为B级的镇静碳素结构钢。<BR>Q235和Q345这两个牌号是工程用钢最典型,生产和使用量最大,用途最广泛的牌号。这两牌号几乎世界各国都有。<BR>碳素结构钢的牌号组成中,镇静钢符号“Z”和特殊镇静钢符号“TZ”可以省略,例如:质 量等级分别为C级和D级的Q235钢,其牌号表示应为Q235CZ和Q235DTZ,但可以省略为Q235C和 Q235D。<BR>低合金高强度结构钢有镇静钢和特殊镇静钢,但牌号尾部不加写表示脱氧方法的符号。<BR>②专用结构钢一般采用代表钢屈服点的符号“Q”、屈服点数值和表1中规定的代表产品用途 的符号等表示,例如:压力容器用钢牌号表示为“Q345R”;耐候钢其牌号表示为Q340NH;Q295HP焊接气瓶用钢牌号;Q390g锅炉用钢牌号;Q420q桥梁用钢牌号。<BR>③根据需要,通用低合金高强度结构钢的牌号也可以采用两位阿拉伯数字(表示平均含碳量,以万分之几计)和化学元素符号,按顺序表示;专用低合金高强度结构钢的牌号,也可以采用两位阿拉伯数字(表示平均含碳量,以万分之几计)和化学元素符号,以及表1中规定代表产品用途的符号,按顺序表示。<BR>2、优质碳素结构钢和优质碳素弹簧钢牌号表示方法<BR>优质碳素结构钢采用两位阿拉伯数字(以万分之几计表示平均含碳量)或阿拉伯数字和元素符号、表1中规定的符号组合成牌号。<BR>①沸腾钢和半镇静钢,在牌号尾部分别加符号“F”和“b”。例如:平均含碳量为0.08%的沸腾钢,其牌号表示为“08F”;平均含碳量为0.10%的半镇静钢,其牌号表示为“10b”。<BR>②镇静钢(S、P分别≤0.035%)一般不标符号。例如:平均含碳量为0.45%的镇静钢,其牌号表示为“45”。<BR>③较高含锰量的优质碳素结构钢,在表示平均含碳量的阿拉伯数字后加锰元素符号。例如: 平均含碳量为0.50%,含锰量为0.70%~1.00%的钢,其牌号表示为“50Mn”。<BR>④高级优质碳素结构钢(S、P分别≤0.030%),在牌号后加符号“A”。例如:平均含碳量为0.45%的高级优质碳素结构钢,其牌号表示为“45A”。<BR>⑤特级优质碳素结构钢(S≤0.020%、P≤0.025%),在牌号后加符号“E”。例如:平均含碳量为0.45%的特级优质碳素结构钢,其牌号表示为“45E”。<BR>优质碳素弹簧钢牌号的表示方法与优质碳素结构钢牌号表示方法相同(65、70、85、65Mn钢 在GB/T1222和GB/T 699两个标准中同时分别存在)。<BR>3、合金结构钢和合金弹簧钢牌号表示方法<BR>①合金结构钢牌号采用阿拉伯数字和标准的化学元素符号表示。<BR>用两位阿拉伯数字表示平均含碳量(以万分之几计),放在牌号头部。<BR>合金元素含量表示方法为:平均含量小于1.50%时,牌号中仅标明元素,一般不标明含量; 平均合金含量为1.50%~2.49%、2.50%~3.49%、3.50%~4.49%、4.50%~5.49%、……时,在合金元素后相应写成2、3、4、5……。<BR>例如:碳、铬、锰、硅的平均含量分别为0.30%、0.95%、0.85%、1.05%的合金结构钢,当S、P含量分别≤0.035%时,其牌号表示为“30CrMnSi”。<BR>高级优质合金结构钢(S、P含量分别≤0.025%),在牌号尾部加符号“A”表示。例如:“30CrMnSiA”。<BR>特级优质合金结构钢(S≤0.015%、P≤0.025%),在牌号尾部加符号“E”,例如:“30CrM nSiE”。<BR>专用合金结构钢牌号尚应在牌号头部(或尾部)加表1中规定代表产品用途的符号。例如,铆螺专用的30CrMnSi钢,钢号表示为ML30CrMnSi。<BR>②合金弹簧钢牌号的表示方法与合金结构钢相同。<BR>例如:碳、硅、锰的平均含量分别为0.60%、1.75%、0.75%的弹簧钢,其牌号表示为“60Si2Mn”。高级优质弹簧钢,在牌号尾部加符号“A”,其牌号表示为“60Si2MnA”。<BR>4、易切削钢牌号表示方法<BR>易切削钢采用标准化学元素符号、表1规定的符号和阿拉伯数字表示。阿拉伯数字表示平均含碳量(以万分之几计)。<BR>①加硫易切削钢和加硫、磷易切削钢,在符号“Y”和阿拉伯数字后不加易切削元素符号。<BR>例如:平均含碳量为0.15%的易切削钢,其牌号表示为“Y15”。<BR>②较高含锰量的加硫或加硫、磷易切削钢在符号“Y”和阿拉伯数字后加锰元素符号。例如 :平均含碳量为0.40%,含锰量为1.20%~1.55%的易切削钢,其牌号表示为“Y40Mn”。<BR>③含钙、铅等易切削元素的易切削钢,在符号“Y”和阿拉伯数字后加易切削元素符号。例 如:“Y15Pb”、“Y45Ca”。<BR>5、非调质机械结构钢牌号表示方法<BR>非调质机械结构钢,在牌号头部分别加符号“YF”和“F”表示易切削非调质机械结构钢和热锻用非调质机械结构钢,牌号表示方法的其他内容与合金结构钢相同。例如:“YF35V”、“F45V”</P>
<P>6、工具钢牌号表示方法<BR>工具钢分为碳素工具钢、合金工具钢和高速工具钢三类。<BR>①碳素工具钢采用标准化学元素符号、表1规定的符号和阿拉伯数字表示。阿拉伯数字表示 平均含碳量(以千分之几计)。<BR>a.普通含锰量碳素工具钢,在工具钢符号“T”后为阿拉伯数字。例如:平均含碳量为0.80%的碳素工具钢,其牌号表示为“T8”。<BR>b.较高含锰量的碳素工具钢,在工具钢符号“T”和阿拉伯数字后加锰元素符号。例如:“ T8Mn”。<BR>c.高级优质碳素工具钢,在牌号尾部加“A”。例如:“T8MnA”。<BR>②合金工具钢和高速工具钢<BR>合金工具钢、高速工具钢牌号表示方法与合金结构钢牌号表示方法相同。采用标准规定的合 金元素符号和阿拉伯数字表示,但一般不标明平均含碳量数字,例如:平均含碳量为1.60% ,含铬、钼,钒含量分别为11.75%、0.50%、0.22%的合金工具钢,其牌号表示为“Cr12MoV”;平均含碳量为0.85%,含钨、钼、铬、钒含量分别为6.00%、5.00%、4.00%、2.00%的高速工具钢,其牌号表示为“W6Mo5Cr4V2”。<BR>若平均含碳量小于1.00%时,可采用一位阿拉伯数字表示含碳量(以千分之几计)。例如:平 均含碳量为0.80%,含锰量为0.95%,含硅量为0.45%的合金工具钢,其牌号表示为“8MnSi”。<BR>低铬(平均含铬量<1.00%)合金工具钢,在含铬量(以千分之几计)前加数字“0”。例如:平均含铬量为0.60%的合金工具钢,其牌号表示为“Cr06”。<BR>7、塑料模具钢牌号表示方法<BR>塑料模具钢牌号除在头部加符号“SM”外,其余表示方法与优质碳素结构钢和合金工具钢牌 号表示方法相同。例如:平均含碳量为0.45%的碳素塑料模具钢,其牌号表示为“SM45”;平均含碳量为0.34%,含铬量为1.70%,含钼量为0.42%的合金塑料模具钢,其牌号表示为“SM3Cr2Mo”。<BR>8、轴承钢牌号表示方法<BR>轴承钢分为高碳铬轴承钢、渗碳轴承钢、高碳铬不锈轴承钢和高温轴承钢等四大类。<BR>①高碳铬轴承钢,在牌号头部加符号“G”,但不标明含碳量。铬含量以千分之几计,其他 合金元素按合金结构钢的合金含量表示。例如:平均含铬量为1.50%的轴承钢,其牌号表示为“GCr15”。<BR>②渗碳轴承钢,采用合金结构钢的牌号表示方法,另在牌号头部加符号“G”。例如:“G20 CrNiMo”。<BR>高级优质渗碳轴承钢,在牌号尾部加“A”。例如:“G20CrNiMoA”。<BR>③高碳铬不锈轴承钢和高温轴承钢,采用不锈钢和耐热钢的牌号表示方法,牌号头部不加符 号“G”。例如:高碳铬不锈轴承钢“9Cr18”和高温轴承钢“10Cr14Mo”。<BR>9、不锈钢和耐热钢的牌号表示方法<BR>不锈钢和耐热钢牌号采用标准规定的合金元素符号和阿拉伯数字表示,为切削不锈钢、易切削耐热钢在牌号头部加“Y”。<BR>一般用一位阿拉伯数字表示平均含碳量(以千分之几计);当平均含碳量≥1.00%时,用两位 阿拉伯数字表示;当含碳量上限<0.10%时,以“0”表示含碳量;当含碳量上限≤0.03%,>0.01%时(超低碳),以“03”表示含碳量;当含碳量上限(≤0.01%时极低碳),以“01”表示含碳量。含碳量没有规定下限时,采用阿拉伯数字表示含碳量的上限数字。<BR>合金元素含量表示方法同合金结构钢。例如:平均含碳量为0.20%,含铬量为13%的不锈钢,其牌号表示为“2Cr13”;含碳量上限为0.08%,平均含铬量为18%,含镍量为9%的铬镍不锈钢,其牌号表示为“0Cr18Ni9”;含碳量上限为0.12%,平均含铬量为17%的加硫易切削铬不锈钢,其牌号表示为“Y1Cr17”;平均含碳量为1.10%,含铬量为17%的高碳铬不锈钢,其牌号表示为“11Cr7”;含碳量上限为0.03%,平均含铬量为19%,含镍量为10%的超低碳不锈钢,其牌号表示为“03Cr19Ni10”;含碳量上限为0.01%,平均含铬量为19%,含镍量为11%的极低碳不锈钢,其牌号表示为“01Cr19Ni11”。<BR>国内现行不锈耐热钢标准是参照JIS标准修订的,但不锈耐热钢牌号表示方法与日本等国个标准不同。我们是用合金元素和平均含C量表示,日本是用表示用途的字母和阿拉伯数字表示。例如不锈钢牌号SUS202、SUS316、SUS430, S-steel(钢),U-use(用途),S-stainless(不锈钢)。例如耐热钢牌号,SUH309、SUH330、SUH660、H-Heatresistins。牌号中不同数字表示各种不同类型的不锈耐热钢。日本表示不锈耐热钢各类不同产品,是在牌号后加上相应的字母,例如不锈钢棒SUS-B,热轧不锈钢板SUS-HP;耐热钢棒SUHB,耐热钢板SUHP。英、美等西方国家,不锈耐热钢牌号表示方法与日本基本一致,主要是用阿拉伯数字表示,而且表示的数字是相同的,即牌号是相同的。因为日本的不锈耐热钢是采用美国的。<BR>10、焊接用钢牌号表示方法<BR>焊接用钢包括焊接用碳素钢、焊接用合金钢和焊接用不锈钢等,其牌号表示方法是在各类焊 接用钢牌号头部加符号“H”。例如:“H08”、“H08Mn2Si”、“H1Cr18Ni9”。<BR>高级优质焊接用钢,在牌号尾部加符号“A”。例如:“H08A”、“08Mn2SiA”。<BR>11、电工用硅钢<BR>钢号由数字、字母和数字组成。<BR>无取向和取向硅钢的字母符号分别为”W”和”Q”<BR>厚度放在前头,字母符号放在中间,铁损数值放在后头,例如30Q113。取向硅钢中,高磁感的字母符号”G”与”Q”放在一起,例如30QG113<BR>字母之后的数字表示铁损值(W/kg)的100倍。<BR>字母“G”者,表示在高频率下检验的;未加“G”者,表示在频率为50周波下检验的。<BR>30Q113表示电工用冷轧取向硅钢产品在50赫频率时的最大单位重量铁损值为1.13W/kg。<BR>冷轧硅钢表示方法与日本标准(JISC2552-86)一致,只是字母符号不同,例如取向硅钢牌号27Q140,与之相对应的JIS牌号为27G140,30QG110与之相应的JIS牌号为30P110(G:表示普通材料,P:表示高取向性)。无取向硅钢牌号35W250,与之相应的JIS牌号为35A250。</P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt">钢铁知识大全(<FONT face="Times New Roman">3</FONT>)<BR><BR>钢材的生产工艺<BR><FONT face="Times New Roman">1</FONT>、<FONT face="Times New Roman"> </FONT>碳素钢的定义及钢中五元素<BR>含碳<FONT face="Times New Roman">2%</FONT>以下的铁碳合金称为钢。<BR>碳素钢中的五元素是指化学成份中的主要组成物,即<FONT face="Times New Roman"> C</FONT>、<FONT face="Times New Roman">Si</FONT>、<FONT face="Times New Roman">Mn</FONT>、<FONT face="Times New Roman">S</FONT>、<FONT face="Times New Roman">P</FONT>(碳、硅、锰、硫、磷)。其次是在炼钢过程中不可避免地<FONT face="Times New Roman"> </FONT>会混入气体,含<FONT face="Times New Roman">O</FONT>、<FONT face="Times New Roman">H</FONT>、<FONT face="Times New Roman">N</FONT>(氧、氢、氮)。此外,用铝<FONT face="Times New Roman">—</FONT>硅脱氧镇静工艺中,必然在钢水中含有<FONT face="Times New Roman"> Al</FONT>,当<FONT face="Times New Roman">Als</FONT>(酸溶铝)<FONT face="Times New Roman">≥0</FONT>。<FONT face="Times New Roman">020%</FONT>时,还有细化晶粒的作用。<FONT face="Times New Roman"> <BR>2</FONT>、<FONT face="Times New Roman"> </FONT>钢铁是怎样炼成的?<BR>炼钢的主要任务是按所炼钢种的质量要求,调整钢中碳和合金元素含量到规定范围之内,并使<FONT face="Times New Roman">P</FONT>、<FONT face="Times New Roman">S</FONT>、<FONT face="Times New Roman">H</FONT>、<FONT face="Times New Roman">O</FONT>、<FONT face="Times New Roman">N</FONT>等杂质的含量降至允<FONT face="Times New Roman"> </FONT>许限量之下。炼钢过程实质上是一个氧化过程,炉料中过剩的碳被氧化,燃烧成<FONT face="Times New Roman">CO</FONT>气体逸出,其它<FONT face="Times New Roman">Si</FONT>、<FONT face="Times New Roman">P</FONT>、<FONT face="Times New Roman">Mn </FONT>等氧化后进入炉渣中。<FONT face="Times New Roman">S</FONT>部份进入<FONT face="Times New Roman"> </FONT>炼渣中,部份则生成<FONT face="Times New Roman">SO2</FONT>排出。当钢水成份和温度达到工艺要求后,即可出钢。为了除去钢中过剩的氧及调整化学成份,可以添加脱氧剂和铁合金或合金元素。<BR><FONT face="Times New Roman">3</FONT>、<FONT face="Times New Roman"> </FONT>转炉炼钢简介<BR>从鱼雷车运来的铁水经过脱硫、挡渣等处理后即可倒入转炉中作为主要炉料,另加<FONT face="Times New Roman">10% </FONT>以下的废钢。然后,向转炉内吹氧燃烧,铁<FONT face="Times New Roman"> </FONT>水中的过量碳被氧化并放出大量热量,当探头测得达到预定的低碳含量时,即停止吹氧<FONT face="Times New Roman"> </FONT>并出钢。<FONT face="Times New Roman"> </FONT>一般在钢包中需进行脱氧及调整成份操作;然后在钢液表面抛上碳化稻壳防止钢水被氧化,即可送往连铸或模铸工区。对要求高的钢种可增加底吹氩、<FONT face="Times New Roman">RH</FONT>真空处理、喷粉处理(喷<FONT face="Times New Roman">SI—CA</FONT>粉及变性石灰)可以有效降低钢中的气体与夹杂,并有进一步降<FONT face="Times New Roman"> </FONT>碳及降硫的作用。在这些炉外精炼措施后还可以最终微调成份,满足优质钢材的需求。<BR><FONT face="Times New Roman">4</FONT>、<FONT face="Times New Roman"> </FONT>初轧<BR>模铸钢锭采取热装、热送新工艺,进入均热炉加热,然后通过初轧机及钢坯连轧机轧成板坯、管坯、小方坯等初轧产品,经过切头、<FONT face="Times New Roman"> </FONT>切尾、表面清理,(火焰清理、打磨)高品质产品则还需对初轧坯进行扒皮和探伤,检验合格后入库。目前初轧厂的产品有初轧板坯、轧制方坯、氧气瓶用钢坯、齿轮用圆管坯、铁路车辆用车轴坯及塑模用钢等。初轧板坯主要供应热轧厂作为原料;轧制方坯除部份外供,主要送往高速线材轧机作原料。由于连铸板坯的先进性,初轧板坯的需求量大为削减,因此转向上述其它产品了。<BR><FONT face="Times New Roman">5</FONT>、<FONT face="Times New Roman"> </FONT>热连轧<BR>用连铸板坯或初轧板坯作原料,经步进式加热炉加热,高压水除鳞后进入粗轧机,粗轧料经切头、尾、再进入精轧机,实施计算机<FONT face="Times New Roman"> </FONT>控制轧制,终轧后即经过层流冷却(计算机控制冷却速率)和卷取机卷取、成为直发卷。直发卷的头、尾往往呈舌状及鱼尾状,厚度、<FONT face="Times New Roman"> </FONT>宽度精度较差,边部常存在浪形、折边、塔形等缺陷。其卷重较重、钢卷内径为<FONT face="Times New Roman">760mm</FONT>。<FONT face="Times New Roman">(</FONT>一般制管行业喜欢使用。<FONT face="Times New Roman">)</FONT>将直发卷经切头、<FONT face="Times New Roman"> </FONT>切尾、切边及多道次的矫直、平整等精整线处理后,再切板或重卷,即成为:热轧钢板、平整热轧钢卷、纵切带等产品。热轧精整卷若经酸洗去除氧化皮并涂油后即成热轧酸洗板卷。该产品有局部替代冷轧板的趋向,价格适中,深受广大用户喜爱。<FONT face="Times New Roman"> </FONT>宝钢新投资的一条热轧酸洗线正在紧张建设中。<BR><FONT face="Times New Roman">6</FONT>、<FONT face="Times New Roman"> </FONT>冷连轧<BR>用热轧钢卷为原料,经酸洗去除氧化皮后进行冷连轧,其成品为轧硬卷,由于连续冷变形引起的冷作硬化使轧硬卷的强度、硬度上升、韧塑指标下降,因此冲压性能将恶化,只能用于简单变形的零件。轧硬卷可作为热镀锌厂的原料,因为热镀锌机组均设置有退<FONT face="Times New Roman"> </FONT>火线。轧硬卷重一般在<FONT face="Times New Roman">6~13.5</FONT>吨,钢卷内径为<FONT face="Times New Roman">610mm</FONT>。<BR>一般冷连轧板、卷均应经过连续退火(<FONT face="Times New Roman">CAPL</FONT>机组)或罩式炉退火消除冷作硬化及轧制应力,达到相应标准规定的力学性能指标。<BR>冷轧钢板的表面质量、外观、尺寸精度均优于热轧板,且其产品厚度右轧薄至<FONT face="Times New Roman">0.18mm</FONT>左右,因此深受广大用户青睐。以冷轧钢卷为基板进行产品的深加工,成为高附加值产品。如电镀锌、热镀锌、耐指纹电镀锌、彩涂钢板卷及减振复合钢板、<FONT face="Times New Roman">PVC </FONT>复膜钢板等,使这些产品具有美观、高抗腐蚀等优良品质,得到了广泛应用。冷轧钢卷经退火后必须进行精整,包括切头、尾、切边、矫平、平整、重卷、或纵剪切板等。冷轧产品广泛应用于汽车制造、家电<FONT face="Times New Roman"> </FONT>产品、仪表开关、建筑、办公家具等行业。钢板捆包后的每包重量为<FONT face="Times New Roman">3~5</FONT>吨。平整分卷重一般为<FONT face="Times New Roman">3~10</FONT>吨<FONT face="Times New Roman">/</FONT>卷。钢卷内径<FONT face="Times New Roman">610mm</FONT>。<BR><FONT face="Times New Roman">7</FONT>、<FONT face="Times New Roman"> </FONT>钢的力学性能<BR><FONT face="Times New Roman">7</FONT>.<FONT face="Times New Roman">1</FONT>拉力试验<BR>按标准制备的拉力试样,安装在拉力试验机的夹头内,对试样缓慢施加单轴向拉伸应力,直至试样被拉断为止的试验称作拉力试验。<BR><FONT face="Times New Roman">7</FONT>.<FONT face="Times New Roman">1</FONT>.<FONT face="Times New Roman">1</FONT>强度<BR>金属材料在外力作用下,抵抗变形和断裂的能力叫强度。强度指标包括:比例极限、弹性极限、屈服强度、抗拉强度等。<BR><FONT face="Times New Roman">7</FONT>.<FONT face="Times New Roman">1</FONT>.<FONT face="Times New Roman">2</FONT>比例极限<BR>对金属施加拉力,金属存在着力与变形成直线比例的阶段,而这个阶段的最大极限负荷<FONT face="Times New Roman">Pp</FONT>除以试样的原横截面积即为比例极限,用<FONT face="Times New Roman"> </FONT>σ<FONT face="Times New Roman"> P</FONT>表示。<BR><FONT face="Times New Roman">7</FONT>.<FONT face="Times New Roman">1</FONT>.<FONT face="Times New Roman">3</FONT>弹性极限<BR>金属受外力作用发生了变形,外力去掉后,能完全恢复原来的形状,这种变形称为弹性变形。金属能保持弹性变形的最大应力称为<FONT face="Times New Roman"> </FONT>弹性极限,用σ<FONT face="Times New Roman">e</FONT>表示。<BR><FONT face="Times New Roman">7</FONT>.<FONT face="Times New Roman">1</FONT>.<FONT face="Times New Roman">4</FONT>抗拉强度<BR>试样拉伸时,在拉断前所承受的最大负荷除以原横截面积所得的应力,称作抗拉强度,用σ<FONT face="Times New Roman">b</FONT>表示。当材料所受的外应力大于其抗拉<FONT face="Times New Roman"> </FONT>强度时,将会发生断裂。因此σ<FONT face="Times New Roman">b</FONT>越高,则表示它能承受愈大的外应力而不致于断裂。<BR>国外标准的结构钢常按抗拉强度来分类,如<FONT face="Times New Roman">SS400</FONT>,其中<FONT face="Times New Roman">400</FONT>即表示<FONT face="Times New Roman">σb</FONT>的最小值为<FONT face="Times New Roman">400MPa</FONT>超高强度钢是指<FONT face="Times New Roman">σb≥1373 Mpa</FONT>的钢。<BR><FONT face="Times New Roman">7</FONT>.<FONT face="Times New Roman">1</FONT>.<FONT face="Times New Roman">5</FONT>屈强比<BR>屈强比即屈服强度与抗拉强度之比值(σ<FONT face="Times New Roman">S/σb</FONT>)。屈服比值越高,则该材料的强度愈高,屈强比值愈低则塑性愈佳,冲压成形性愈好。如深冲钢板的屈强比值为<FONT face="Times New Roman">≤0.65</FONT>。<BR>弹簧钢一般均在弹性极限范围内服役,受载荷时不允许产生塑性变形,因此要求弹簧钢经淬火、回火后具有尽可能高的弹性极限和<FONT face="Times New Roman"> </FONT>屈强比值(σ<FONT face="Times New Roman">S/σb≥0.90</FONT>)此外疲劳寿命与抗拉强度及表面质量往往有很大关连。<BR><FONT face="Times New Roman">7</FONT>.<FONT face="Times New Roman">1</FONT>.<FONT face="Times New Roman">6</FONT>塑性<BR>金属材料在受力破坏前可以经受永久变形的性能称为塑性。塑性指标通常伸长率和断面收缩率表示。伸长率与断面收缩率越高,则<FONT face="Times New Roman"> </FONT>塑性越好。<BR><FONT face="Times New Roman">8</FONT>、冲击韧性<BR>用一定尺寸和形状的金属试样,在规定类型的冲击试验上受冲击负荷折断时,试样刻槽处单位横截面上所消耗的冲击功,称为冲击<FONT face="Times New Roman"> </FONT>韧性以α<FONT face="Times New Roman">k</FONT>表示。<BR>目前常用的<FONT face="Times New Roman">10×10×55mm</FONT>,带<FONT face="Times New Roman">2 mm</FONT>深的<FONT face="Times New Roman">V</FONT>形缺口夏氏冲击试样,标准上直接采用冲击功(<FONT face="Times New Roman">J</FONT>焦耳值)<FONT face="Times New Roman">AK</FONT>,而不是采用<FONT face="Times New Roman">αK</FONT>值。因为单位<FONT face="Times New Roman"> </FONT>面积上的冲击功并无实际意义。<BR>冲击功对于检查金属材料在不同温度下的脆性转化最为敏感,而实际服役条件下的灾难性破断事故,往往与材料的冲击功及服役温<FONT face="Times New Roman"> </FONT>度有关。<FONT face="Times New Roman"> </FONT>因此在有关标准中常常规定某一温度时的冲击功值为多少<FONT face="Times New Roman"> </FONT>、还规定<FONT face="Times New Roman">FATT</FONT>(断口面积转化温度)要低于某一温度的技术条件。所谓<FONT face="Times New Roman">FATT</FONT>,即一组在不同温度下的冲击试样冲断后,对冲击断口进行评定,当脆性断裂占总面积的<FONT face="Times New Roman">50%</FONT>时所对应的温度。由于钢板厚度的影响,对厚度<FONT face="Times New Roman">≤10mm</FONT>的钢板,可取得<FONT face="Times New Roman">3/4</FONT>小尺寸冲击试样(<FONT face="Times New Roman">7.5×10×55mm</FONT>)或<FONT face="Times New Roman">1/2</FONT>小尺寸冲击试样(<FONT face="Times New Roman">5×10×55mm</FONT>)。但是一定要注意,同规格及同一温度下的冲击功值才可相互比较。只有在标准规定的条件下,才可按标准的换算方法,折算<FONT face="Times New Roman"> </FONT>成标准冲击试样的冲击功,再相互比较。<FONT face="Times New Roman"> <BR>9</FONT>、硬度试验<BR>金属材料抵抗压头(淬硬的钢球或具有<FONT face="Times New Roman">1200</FONT>圆锥或角锥的金刚石压头)压陷表面的能力称为硬度。<FONT face="Times New Roman"> </FONT>根据试验方法和适用范围的不同,硬度可分为布氏硬度、洛氏硬度、维氏硬度、肖氏硬度以及显微硬度、高温硬度等。<BR>冶金产品常用的是布氏硬度和洛氏硬度。<BR><FONT face="Times New Roman">10</FONT>、宝钢企业标准(<FONT face="Times New Roman">Q/BQB</FONT>)<BR>宝钢企标中的钢号大致可分为三个来源<FONT face="Times New Roman">: </FONT>即从日本<FONT face="Times New Roman">JIS</FONT>标准、德国<FONT face="Times New Roman">DIN</FONT>标准移植及自行开发研制的钢号。从日本<FONT face="Times New Roman">JIS</FONT>标准中移植来的钢号,一般首位常为<FONT face="Times New Roman">S</FONT>(<FONT face="Times New Roman">Steel</FONT>);从<FONT face="Times New Roman">DIN</FONT>标准移植来的钢号,一般常以<FONT face="Times New Roman">ST</FONT>开头(<FONT face="Times New Roman">Stahl</FONT>德文中的<FONT face="Times New Roman">“</FONT>钢<FONT face="Times New Roman">”</FONT>);<FONT face="Times New Roman"> </FONT>宝钢自行开发研制的钢号,一般首位常以宝钢的拼音首位<FONT face="Times New Roman">B</FONT>开头。<BR><FONT face="Times New Roman">11</FONT>、结构用热连轧、冷连轧钢板及钢带<BR>结构钢一般按强度分类,在钢号中的数字往往代表抗拉强度的最低值。由于该类钢常用于制作结构件,因此称作为结构钢。结构钢的强化机制倾向于降碳增锰固溶强化铁素体、细化珠光体和添加微合金的析出强化、沉淀强化和细晶强化,以确保在提高强<FONT face="Times New Roman"> </FONT>度的同时仍保持较好的韧、塑指标并兼具良好的焊接性能。</P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt">钢铁知识大全(<FONT face="Times New Roman">4</FONT>)<BR><BR>什么是冷扎,热扎<BR>冷轧和热轧是两种不同的轧钢技术,顾名思义,冷轧就是在钢在常温情况下进行扎制,这种钢的硬度大。热轧就是钢在高温情况下扎制<FONT face="Times New Roman"> <BR></FONT>(<FONT face="Times New Roman">1</FONT>)热轧:<BR><FONT face="Times New Roman">1</FONT>、厚度:<FONT face="Times New Roman">1.2mm—8/12mm</FONT>(厚度不同,价格不同)<BR><FONT face="Times New Roman">2</FONT>、宽度:<FONT face="Times New Roman">1000mm/1250mm/1500mm</FONT>(非标宽度一般要加价)<BR><FONT face="Times New Roman">3</FONT>、牌号:<BR>国内:(硬、含碳高)<FONT face="Times New Roman"> Q235—Q215—Q195 </FONT>(软、含碳低)<BR>日本:<FONT face="Times New Roman"> SS400—SS330—SPHC</FONT>(国内一般套用)<BR>独联体:<FONT face="Times New Roman"> 08KP--08YU</FONT>(较强拉深、深冲)<BR>德国:<FONT face="Times New Roman"> ST12— ST13— ST14</FONT>(较强拉深、深冲)<BR>珠钢:<FONT face="Times New Roman">ZJ330</FONT>等<BR><FONT face="Times New Roman">4</FONT>、卷重:主要是<FONT face="Times New Roman">15</FONT>吨<FONT face="Times New Roman">/</FONT>卷,也有要求<FONT face="Times New Roman">10</FONT>吨以下<FONT face="Times New Roman">/</FONT>卷。要考虑开平机的承重、吊装设备的承重等问题<FONT face="Times New Roman">.<BR>5</FONT>、生产能力:<BR>厚度为<FONT face="Times New Roman">0.9/1.2/1.5</FONT>只有珠钢能够生产<BR>厚度为<FONT face="Times New Roman">1.5mm</FONT>邯钢、宝钢能够生产(邯钢质量较差)<BR>厚度为<FONT face="Times New Roman">1.8mm</FONT>本钢、鞍钢、太钢能够生产<BR><FONT face="Times New Roman">6</FONT>、产品质量及价格:<BR>独联体:质量较差、价低。<FONT face="Times New Roman">08KP</FONT>生产厂家有乌克兰<FONT face="Times New Roman">ILLCHY</FONT>、<FONT face="Times New Roman">ZAPROSTAL</FONT>钢厂、哈撒克斯坦<FONT face="Times New Roman">INSPAT</FONT>钢厂(其中乌克兰的质量最差,价格最低)。<BR><FONT face="Times New Roman">08YU</FONT>生产厂家有俄罗斯(<FONT face="Times New Roman">MMK</FONT>)玛钢(<FONT face="Times New Roman">08YU</FONT>质量好于<FONT face="Times New Roman">08KP</FONT>)<BR>日本:质量好、价高主要生产厂家为六大高炉工厂:新日铁、住友、<FONT face="Times New Roman">NKK</FONT>、川崎等。<BR>韩国:质量好、价高主要生产厂家为<FONT face="Times New Roman">POSCO</FONT>(浦项)<BR>台湾:质量好、价格高,主要生产厂家为中钢、烨隆。<BR>南非:质量好于独联体,仅次于日韩,主要生产厂家为<FONT face="Times New Roman">SODHNA</FONT>。<BR><FONT face="Times New Roman">1.5—2.0</FONT>(不包括<FONT face="Times New Roman">1.5</FONT>,包括<FONT face="Times New Roman">2.0</FONT>)国内厂家质量较差,<FONT face="Times New Roman">2.0</FONT>以上质量可以满足使用要求。<BR><FONT face="Times New Roman">1.5</FONT>以下主要需要进口,<FONT face="Times New Roman">1.8—2.95</FONT>使用独联体的较多。<FONT face="Times New Roman"> <BR></FONT>(<FONT face="Times New Roman">2</FONT>)冷轧:<BR><FONT face="Times New Roman">1</FONT>、厚度:<FONT face="Times New Roman">0.25mm—3.00mm</FONT>(厚度不同,价格不同)<BR><FONT face="Times New Roman">2</FONT>、宽度:<FONT face="Times New Roman">1000mm/1250mm</FONT>(非标宽度一般要加价)<BR><FONT face="Times New Roman">3</FONT>、牌号:<BR>国内:(硬、含碳高)<FONT face="Times New Roman"> Q235—Q195 </FONT>(软、含碳低)(用<FONT face="Times New Roman">Q195</FONT>较多)<BR>日本:<FONT face="Times New Roman">SPCC-SD—SPCD-SD—SPCE-SD</FONT>(国内一般套用)<BR>独联体:<FONT face="Times New Roman">08KP--08YU</FONT>(较强拉深、深冲)<BR>德国:<FONT face="Times New Roman">ST12— ST13— ST14/ ST16</FONT>(较强拉深、深冲)<BR><FONT face="Times New Roman">4</FONT>、使用现状<BR><FONT face="Times New Roman">1.0mm</FONT>以下主要需要进口。<BR>日本:主要是<FONT face="Times New Roman">0.6mm/0.7mm</FONT>以下<BR>独联体:主要是<FONT face="Times New Roman">1.1mm</FONT>以下<BR>国内:主要是<FONT face="Times New Roman">0.8mm</FONT>以上<FONT face="Times New Roman">—3.0mm</FONT>以下<BR><FONT face="Times New Roman">5</FONT>、产品质量:<BR>日、韩:质量最好,如<FONT face="Times New Roman">POSCO</FONT>等<BR>国内:中档,宝钢最好、鞍钢、本钢、攀钢、武钢其次<BR>独联体:质量最差。<BR>主要生产厂家同热轧。</P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt">钢铁知识大全(<FONT face="Times New Roman">5</FONT>)<BR><BR>不锈钢的有关实用知识<BR>一、不锈钢热轧钢板<BR>不锈钢热轧钢板是用热轧工艺生产的不锈钢钢板。厚度不大于<FONT face="Times New Roman">3mm</FONT>的为薄板,厚度大于<FONT face="Times New Roman">3mm</FONT>的为厚板。用于化工、石油、机械、船舶等行业制造耐蚀零件、容器和设备。其分类和牌号如下:<BR><FONT face="Times New Roman">1</FONT>.奥氏体型钢<BR><FONT face="Times New Roman">(1)1Cr17Mn6Ni15N</FONT>;<FONT face="Times New Roman">(2)1Cr18Mn8Ni5N</FONT>;<FONT face="Times New Roman">(3)1Cr18Ni9</FONT>;<FONT face="Times New Roman">(4)1Cr18Ni9Si3</FONT>;<FONT face="Times New Roman">(5)0Cr18Ni9</FONT>;<FONT face="Times New Roman"> (6)00Cr19Ni10</FONT>;<FONT face="Times New Roman">(7)0Cr19Ni9N</FONT>;<FONT face="Times New Roman">(8)0Cr19Ni10NbN</FONT>;<FONT face="Times New Roman">(9)00Cr18Ni10N</FONT>;<FONT face="Times New Roman">(10)1Cr18Ni12</FONT>;(<FONT face="Times New Roman">11</FONT>)<FONT face="Times New Roman"> 0Cr23Ni13</FONT>;<FONT face="Times New Roman">(12)0Cr25Ni20</FONT>;<FONT face="Times New Roman">(13) 0Cr17Ni12Mo2</FONT>;<FONT face="Times New Roman">(14) 00Cr17Ni14Mo2</FONT>;<FONT face="Times New Roman"> (15) 0Cr17Ni12Mo2N</FONT>;<FONT face="Times New Roman">(16) 00Cr17Ni13Mo2N</FONT>;<FONT face="Times New Roman">(17) 1Cr18Ni12Mo2Ti</FONT>;<FONT face="Times New Roman">(18) 0Cr18Ni12Mo2Ti</FONT>;<FONT face="Times New Roman"> (19) 1Cr18Ni12Mo3Ti</FONT>;<FONT face="Times New Roman">(20) 0Cr18Ni12Mo3Ti</FONT>;<FONT face="Times New Roman">(21) 0Cr18Ni12Mo2Cu2</FONT>;<FONT face="Times New Roman"> (22) 00Cr18Ni14Mo2Cu2</FONT>;<FONT face="Times New Roman">(23) 0Cr19Ni13Mo3</FONT>;<FONT face="Times New Roman">(24) 00Cr19Ni13Mo3</FONT>;<FONT face="Times New Roman">(25) 0Cr18Ni16Mo5</FONT>;<FONT face="Times New Roman"> (26) 1Cr18Ni9Ti</FONT>;<FONT face="Times New Roman">(27) 0Cr18Ni10Ti</FONT>;<FONT face="Times New Roman">(28) 0Cr18Ni11Nb</FONT>;<FONT face="Times New Roman">(29) 0Cr18Ni13Si4<BR>2</FONT>.奥氏体<FONT face="Times New Roman">——</FONT>铁素体型钢<BR>(<FONT face="Times New Roman">30</FONT>)<FONT face="Times New Roman">0Cr26Ni5Mo2</FONT>;(<FONT face="Times New Roman">31</FONT>)<FONT face="Times New Roman">00Cr18Ni5Mo3Si2</FONT>;<BR><FONT face="Times New Roman">3</FONT>.铁素体型钢<BR>(<FONT face="Times New Roman">32</FONT>)<FONT face="Times New Roman">0Cr13Al</FONT>;<FONT face="Times New Roman">(33) 00Cr12</FONT>;<FONT face="Times New Roman">(34)1Cr15</FONT>;<FONT face="Times New Roman">(35)1Cr17</FONT>;<FONT face="Times New Roman">(36)1Cr17Mo</FONT>;<FONT face="Times New Roman">(37)00Cr17Mo</FONT>;<FONT face="Times New Roman">(38)00Cr18Mo2</FONT>;<FONT face="Times New Roman">(39)00Cr30Mo2</FONT>;<FONT face="Times New Roman">(40)00Cr27Mo<BR>4</FONT>.马氏体型钢<BR>(<FONT face="Times New Roman">41</FONT>)<FONT face="Times New Roman">1Cr12</FONT>;(<FONT face="Times New Roman">42</FONT>)<FONT face="Times New Roman">0Cr13</FONT>;(<FONT face="Times New Roman">43</FONT>);<FONT face="Times New Roman">1Cr13</FONT>;(<FONT face="Times New Roman">44</FONT>)<FONT face="Times New Roman">2Cr13</FONT>;(<FONT face="Times New Roman">45</FONT>)<FONT face="Times New Roman">3Cr13</FONT>;(<FONT face="Times New Roman">46</FONT>)<FONT face="Times New Roman">4Cr13</FONT>;(<FONT face="Times New Roman">47</FONT>)<FONT face="Times New Roman">3Cr16</FONT>;(<FONT face="Times New Roman">48</FONT>)<FONT face="Times New Roman">7Cr17<BR>5</FONT>.沉淀硬化型钢<BR>(<FONT face="Times New Roman">49</FONT>)<FONT face="Times New Roman">0Cr17Ni7Al <BR></FONT>二、不锈钢冷轧钢板<BR>不锈钢冷轧钢板是用冷轧工艺生产的不锈钢钢板,厚度不大于<FONT face="Times New Roman">3mm</FONT>的为薄板,厚度大于<FONT face="Times New Roman">3mm</FONT>的为厚板。用于制作耐腐蚀部件,石油、化工的管道、容器、医疗器械、船舶设备等,其分类和牌号如下:<BR><FONT face="Times New Roman">1</FONT>.奥氏体型钢<BR>除与热轧部分相同外(<FONT face="Times New Roman">29</FONT>种),还有:(<FONT face="Times New Roman">1</FONT>)<FONT face="Times New Roman">2Cr13Mn9Ni4(2)1Cr17Ni7(3) 1Cr17Ni8<BR>2</FONT>.奥氏体<FONT face="Times New Roman">——</FONT>铁素体型钢<BR>除与热轧部分相同外(<FONT face="Times New Roman">2</FONT>种),还有:<FONT face="Times New Roman">(1)1Cr18Ni11Si4AlTi(2) 1Cr21Ni5Ti<BR>3</FONT>.铁素体型钢<BR>除与热轧部分相同外(<FONT face="Times New Roman">9</FONT>种),还有:<FONT face="Times New Roman">00Cr17]<BR>4</FONT>.马氏体型钢<BR>除与热轧部分相同外(<FONT face="Times New Roman">8</FONT>种),还有<FONT face="Times New Roman">1Cr17Ni2<BR>5.</FONT>沉淀硬化型钢:同热轧部分<BR>三、铁素体、奥氏体、马氏体简介<BR>大家知道固态金属及合金都是晶体,即在其内部原子是按一定规律排列的,排列的方式一般有三种即:体心立方晶格结构、面心立方晶格结构和密排六方晶格结构。金属是由多晶体组成的,它的多晶体结构是在金属结晶过程中形成的。组成铁碳合金的铁具有两种晶格结构:<FONT face="Times New Roman">910℃</FONT>以下为具有体心立方晶格结构的<FONT face="Times New Roman">α—</FONT>铁,<FONT face="Times New Roman">910℃</FONT>以上为具有面心立方晶格结构的<FONT face="Times New Roman">Υ—</FONT>铁。如果碳原子挤到铁的晶格中去,而又不破坏铁所具有的晶格结构,这样的物质称为固溶体。碳溶解到<FONT face="Times New Roman">α—</FONT>铁中形成的固溶体称铁素体,它的溶碳能力极低,最大溶解度不超过<FONT face="Times New Roman">0.02%</FONT>。而碳溶解到<FONT face="Times New Roman">Υ—</FONT>铁中形成的固溶体则称奥氏体,它的溶碳能力较高,最高可达<FONT face="Times New Roman">2%</FONT>。奥氏体是铁碳合金的高温相。<BR>钢在高温时所形成的奥氏体,过冷到<FONT face="Times New Roman">727℃</FONT>以下时变成不稳定的过冷奥氏体。如以极大的冷却速度过冷到<FONT face="Times New Roman">230℃</FONT>以下,这时奥氏体中的碳原子已无扩散的可能,奥氏体将直接转变成一种含碳过饱和的<FONT face="Times New Roman">α</FONT>固溶体,称为马氏体。由于含碳量过饱和,引起马氏体强度和硬度提高、塑性降低,脆性增大。<BR>不锈钢的耐蚀性主要来源于铬。实验证明,只有含铬量超过<FONT face="Times New Roman">12%</FONT>时钢的耐蚀性能才会大大提高,因此,不锈钢中的含铬量一般均不低于<FONT face="Times New Roman">12%</FONT>。由于含铬量的提高,对钢的组织也有很大影响,当铬含量高而碳含量很少时,铬会使铁碳平衡,图上的<FONT face="Times New Roman">Υ</FONT>相区缩小,甚至消失,这种不锈钢为铁素体组织结构,加热时不发生相变,称为铁素体型不锈钢。<BR>当含铬量较低(但高于<FONT face="Times New Roman">12%</FONT>),碳含量较高,合金在从高温冷却时,极易形成马氏体,故称这类钢为马氏体型不锈钢。<BR>镍可以扩展Υ相区,使钢材具有奥氏体组织。如果镍含量足够多,使钢在室温下也具有奥氏体组织结构,则称这种钢为奥氏体型不锈钢。<BR><BR>四、我国和日本常用不锈钢钢号的近似对照<BR><FONT face="Times New Roman">1</FONT>.对照表:<BR>日本(<FONT face="Times New Roman">JIS</FONT>)<FONT face="Times New Roman"> </FONT>中国(<FONT face="Times New Roman">GB</FONT>)<BR><FONT face="Times New Roman">SUS304 0Cr18Ni9(0Cr19Ni9)<BR>SUS 304L 00Cr19Ni10(00Cr18Ni10)<BR>SUS 309S 0Cr23Ni13<BR>SUS 310S 0Cr25Ni20(1Cr25Ni20Si2)<BR>SUS 316 0Cr17Ni12Mo2(0Cr18Ni12Mo2Ti)<BR>SUS 316L 00Cr17Ni14Mo2<BR>SUS 321 1Cr18Ni9Ti(0Cr18Ni9Ti)<BR>SUS 430 1Cr17<BR>SUS 403 1Cr12<BR>SUS 410 1Cr13<BR>SUS 420J1 2Cr13<BR>SUS 420J2 3Cr13<BR>SUS 431 1Cr17Ni2<BR>2</FONT>.牌号后掇<FONT face="Times New Roman">NO</FONT>.<FONT face="Times New Roman">1</FONT>表示热轧后进行热处理、酸洗或类似的处理;<FONT face="Times New Roman">NO</FONT>.<FONT face="Times New Roman">2</FONT>表示冷轧后进行热处理、酸洗或相应处理;<FONT face="Times New Roman">NO</FONT>.<FONT face="Times New Roman">2B</FONT>表示冷轧后进行热处理、酸洗或类似的处理,最后经冷轧获得适当光洁度。如<FONT face="Times New Roman">304NO</FONT>.<FONT face="Times New Roman">1</FONT>不锈钢板表示牌号为<FONT face="Times New Roman">304</FONT>的热轧不锈钢板。再如<FONT face="Times New Roman">321-2B</FONT>表示牌号为<FONT face="Times New Roman">321</FONT>的冷轧不锈钢板,表面要求冷轧后进行热处理,酸洗或类似的处理,最后经冷轧获得适当光洁度。<BR>不锈钢牌号与美国、日本、欧洲对照表<BR>类别<FONT face="Times New Roman"> </FONT>中国<FONT face="Times New Roman"> </FONT>美国<FONT face="Times New Roman"> </FONT>日本<FONT face="Times New Roman"> </FONT>欧洲<FONT face="Times New Roman"> <BR></FONT>马氏体不锈钢<FONT face="Times New Roman"> Cr13</FONT>型<FONT face="Times New Roman">410SUS410SAF2301<BR>1Cr17Ni2431SUS431SAF2321<BR>9Cr18440CSUS440c</FONT> <FONT face="Times New Roman"> <BR>0Cr17Ni4Cu4Nb17-4PHSUH630</FONT> <FONT face="Times New Roman"> <BR>1Cr12Ni3MoWVXM32</FONT> <FONT face="Times New Roman"> DIN1.4313<BR>2Cr12MoVNbN SUH600</FONT> <FONT face="Times New Roman"> <BR>2Cr12NiMoWV</FONT> <FONT face="Times New Roman"> SUH616</FONT> <FONT face="Times New Roman"> <BR></FONT>双相钢<FONT face="Times New Roman"> </FONT> <FONT face="Times New Roman">00Cr18Ni5Mo3Si2S315003RE60</FONT> <FONT face="Times New Roman"> <BR>00Cr22Ni5Mo3NS31803329J3L1SAF2205<BR>00Cr25Ni6Mo2N</FONT> <FONT face="Times New Roman"> 329J1L1R-4</FONT> <FONT face="Times New Roman"> <BR>00Cr25Ni7Mo3NS31260329J4LSAF2507<BR>00Cr25Ni6Mo3CuN S32550 </FONT> <FONT face="Times New Roman"> </FONT> <FONT face="Times New Roman"> <BR></FONT>铁素体<FONT face="Times New Roman"> 0Cr13410SSUS410S</FONT> <FONT face="Times New Roman"> <BR>00Cr17Ti</FONT> <FONT face="Times New Roman"> </FONT> <FONT face="Times New Roman"> </FONT> <FONT face="Times New Roman"> <BR>00Cr18Mo2Ti</FONT> <FONT face="Times New Roman"> </FONT> <FONT face="Times New Roman"> </FONT> <FONT face="Times New Roman"> <BR></FONT>奥氏体不锈钢<FONT face="Times New Roman"> 0Cr18Ni9Ti321SUS321SAF2337<BR>00Cr19Ni10304LSUS304L</FONT> <FONT face="Times New Roman"> <BR>0Cr17Ni12Mo2316SUS316SAF2343<BR>0Cr17Ni14Mo2316LSUS312L</FONT> <FONT face="Times New Roman"> <BR>00Cr19Ni13Mo3317LSUS317L</FONT> <FONT face="Times New Roman"> <BR>ZG00Cr19Ni10CF3SCS19A</FONT> <FONT face="Times New Roman"> <BR>ZG00Cr17Ni14Mo2CF3MSCS16A</FONT> <FONT face="Times New Roman"> <BR>0Cr25Ni20310SSUS310S</FONT> <FONT face="Times New Roman"> <BR>00Cr20Ni18Mo6CuNS31254</FONT> <FONT face="Times New Roman"> 254SMO<BR>00Cr20Ni25Mo4.5Cu904L</FONT> <FONT face="Times New Roman"> 2RK65<BR>00Cr25Ni22MoNS31050</FONT> <FONT face="Times New Roman"> 2RE6</FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face="Times New Roman"></FONT> </P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt">钢铁知识大全(<FONT face="Times New Roman">6</FONT>)<BR><BR>钢管的定义和分类(一)<BR>钢管是一种中空的长条钢材,大量用作输送流体的管道,如石油、天燃气、水、煤气、蒸气等,另外,在搞弯、抗扭强度相同时,重量较轻,所以也广泛用于制造机械零件和工程结构。也常用作生产各种常规武器、枪管、炮弹等。<FONT face="Times New Roman"> <BR></FONT>钢管的分类:钢管分无缝钢管和焊接钢管(有缝管)两大类。按断面形状又可分为圆管和异形管,广泛应用的是圆形钢管,但也有一些方形、矩形、半圆形、六角形、等边三角形、八角形等异形钢管。<FONT face="Times New Roman"> </FONT>对于承受流体压力的钢管都要进行液压试验来检验其耐压能力和质量,在规定的压力下不发生泄漏、浸湿或膨胀为合格,有些钢管还要根据标准或需方要求进行卷边试验、扩口试验、压扁试验等。<FONT face="Times New Roman"> <BR></FONT>无缝钢管:无缝钢管是用钢锭或实心管坯经穿孔制成毛管,然后经热轧、冷轧或冷拨制成。无缝钢管的规格用外径<FONT face="Times New Roman">*</FONT>壁厚毫米数表示。无缝钢管分热轧和冷轧(拨)无缝钢管两类。<FONT face="Times New Roman"> </FONT>热轧无缝钢管分一般钢管,低、中压锅炉钢管,高压锅炉钢管、合金钢管、不锈钢管、石油裂化管、地质钢管和其它钢管等。冷轧(拨)无缝钢管除分一般钢管、低中压锅炉钢管、高压锅炉钢管、合金钢管、不锈钢管、石油裂化管、其它钢管外,还包括碳素薄壁钢管、合金薄壁钢管、不锈薄壁钢管、异型钢管。热轧无缝管外径一般大于<FONT face="Times New Roman">32mm</FONT>,壁厚<FONT face="Times New Roman">2.5-75mm</FONT>,冷轧无缝钢管处径可以到<FONT face="Times New Roman">6mm</FONT>,壁厚可到<FONT face="Times New Roman">0.25mm</FONT>,薄壁管外径可到<FONT face="Times New Roman">5mm</FONT>壁厚小于<FONT face="Times New Roman">0.25mm</FONT>,冷轧比热轧尺寸精度高。<FONT face="Times New Roman"> <BR></FONT>一般用无缝钢管是用<FONT face="Times New Roman">10</FONT>、<FONT face="Times New Roman">20</FONT>、<FONT face="Times New Roman">30</FONT>、<FONT face="Times New Roman">35</FONT>、<FONT face="Times New Roman">45</FONT>等优质碳结钢<FONT face="Times New Roman">16Mn</FONT>、<FONT face="Times New Roman">5MnV</FONT>等低合金结构钢或<FONT face="Times New Roman">40Cr</FONT>、<FONT face="Times New Roman">30CrMnSi</FONT>、<FONT face="Times New Roman">45Mn2</FONT>、<FONT face="Times New Roman">40MnB</FONT>等合结钢热轧或冷轧制成的。<FONT face="Times New Roman">10</FONT>、<FONT face="Times New Roman">20</FONT>等低碳钢制造的无缝管主要用于流体输送管道。<FONT face="Times New Roman">45</FONT>、<FONT face="Times New Roman">40Cr</FONT>等中碳钢制成的无缝管用来制造机械零件,如汽车、拖拉机的受力零件。一般用无缝钢管要保证强度和压扁试验。热轧钢管以热轧状态或热处理状态交货;冷轧以热以热处理状态交货。<BR>钢管的定义和分类(二)<BR>低中压锅炉用无缝钢管:用于制造各种低中压锅炉、过热蒸汽管、沸水管、水冷壁管及机车锅炉用过热蒸汽管、大烟管、小烟管和拱砖管等。用优质碳素结构钢热轧或冷轧(拨)无缝钢管。主要用<FONT face="Times New Roman">10</FONT>、<FONT face="Times New Roman">20</FONT>号钢制造,除保证化学成分和机械性能外要做水压试验,卷边、扩口、压扁等试验。热轧以热轧状态交货、冷轧(拨)以热处理状态交货。<FONT face="Times New Roman"> <BR></FONT>高压锅炉钢管:主要用来制造高压及其以上压力的蒸汽锅炉管道等用的优质碳素结构钢、合金结构钢和不锈耐热钢无缝钢管、这些锅炉管经党处于高温和高压下工作、管子在高温烟气和水蒸汽的作用下还会发生氧化和腐蚀,因此要求钢管有高的持久强度、高的抗氧化性能,并具有良好的组织稳定性,采用钢号有:优质碳素结构钢钢号有<FONT face="Times New Roman">20G</FONT>、<FONT face="Times New Roman">20MnG</FONT>、<FONT face="Times New Roman">25MnG</FONT>;合金结构钢钢号<FONT face="Times New Roman">15MoG</FONT>、<FONT face="Times New Roman">20MoG</FONT>、<FONT face="Times New Roman">12CrMoG</FONT>、<FONT face="Times New Roman">15CrMoG</FONT>、<FONT face="Times New Roman">12Cr2MoG</FONT>、<FONT face="Times New Roman">12CrMoVG</FONT>、<FONT face="Times New Roman">12Cr3MoVSiTiB</FONT>等;有锈耐热钢常用<FONT face="Times New Roman">1Cr18Ni9</FONT>、<FONT face="Times New Roman">1Cr18Ni11Nb</FONT>高压锅炉管除保证化学成分和机械性能外,要逐根做水压试验,要作扩口、压扁试验。钢管以热处理状态交货。此外,对成品钢管显微组织、晶粒度、脱碳层也有一定要求。<FONT face="Times New Roman"> <BR></FONT>地质钻探及石油钻控用无缝钢管;为探明地下岩层结构、地下水、石油、天然气及矿产资源情况,利用钻机打井。石油、天然气开采更离不开打井,地质钻控用石油钻探用无缝钢管是钻井的主要器材,主要包括岩芯外管、岩芯内管、套管、钻杆等。由于钻探用管要深入到几千米地层深度工作,工作条件极为复杂,钻杆承受拉、压、弯曲、扭转和不均衡冲击载荷等应力作用,还要受到泥浆、岩石磨损,因此,要求管材必须具有足够的强度、硬度、耐磨性和冲击韧性,钢管用钢用“<FONT face="Times New Roman">DZ”</FONT>(地质的汉语拼音字头)加数字一代表钢屈服点表示,常用的钢号有<FONT face="Times New Roman">DZ45</FONT>的<FONT face="Times New Roman">45MnB</FONT>、<FONT face="Times New Roman">50Mn</FONT>;<FONT face="Times New Roman">DZ50</FONT>的<FONT face="Times New Roman">40Mn2</FONT>、<FONT face="Times New Roman">40Mn2Si</FONT>;<FONT face="Times New Roman">DZ55</FONT>的<FONT face="Times New Roman">40Mn2Mo</FONT>、<FONT face="Times New Roman">40MnVB</FONT>;<FONT face="Times New Roman">DZ60</FONT>的<FONT face="Times New Roman">40MnMoB</FONT>、<FONT face="Times New Roman">DZ65</FONT>的<FONT face="Times New Roman">27MnMoVB</FONT>。钢管都以热处理状态交货。<BR>石油裂化管:用于石油炼厂的炉管、热交换器管和管道用无缝管。常用优质碳素钢(<FONT face="Times New Roman">10</FONT>、<FONT face="Times New Roman">20</FONT>)、合金钢(<FONT face="Times New Roman">12CrMo</FONT>、<FONT face="Times New Roman">15CrMo</FONT>)、耐热钢(<FONT face="Times New Roman">12Cr2Mo</FONT>、<FONT face="Times New Roman">15Cr5Mo</FONT>)、不锈钢(<FONT face="Times New Roman">1Cr18Ni9</FONT>、<FONT face="Times New Roman">1Cr18Ni9Ti</FONT>)制造。钢管除得证化学成分和各种机械性能外,还要保证水压、压扁、扩口等试验,及表面质量和无损检验。钢管在热处理状态下交货。<FONT face="Times New Roman"> </FONT>不锈钢管:用各种不锈钢热轧,冷轧的不锈钢管,广泛应用于石油、化工设备管道和各种用途的不锈钢结构零件,除应保证化学成分和机械性能,凡用作承受流体压力的钢管要保证水压试验合格。各种专用钢管要按规定保证条件。<BR>焊接钢管:也叫焊管,是用钢板或钢带经过弯曲成型,然后经焊接制成。按焊缝形式分为直缝焊管和螺旋焊管。按用途又分为一般焊管、镀锌焊管、吹氧焊管、电线套管、公制焊管、托辊管、深井泵管、汽车用管、变压器管、电焊薄壁管、电焊异型管和螺旋焊管。<FONT face="Times New Roman"> </FONT>一般焊管:一般焊管用来输送低压流体。用<FONT face="Times New Roman">Q195A</FONT>、<FONT face="Times New Roman">Q215A</FONT>、<FONT face="Times New Roman">Q235A</FONT>钢制造<FONT face="Times New Roman"> </FONT>。也可采用易于焊接的其它软钢制造。钢管要进行水压、弯曲、压扁等实验,对表面质量有一定要求,通常交货长度为<FONT face="Times New Roman">4-10m</FONT>,常要求定尺(或倍尺)交货。焊管的规格用公称口径表示(毫米或英寸)公称口径与实际不同,焊管按规定壁厚有普通钢管和加厚钢管两种,钢管按管端形式又分带螺纹和不带螺纹两种。<BR>钢管的定义和分类(三)<BR>镀锌钢管:为提高钢管的耐腐蚀性能,对一般钢管(黑管)进行镀锌。镀锌钢管分热镀锌和电钢锌两种,热镀锌镀锌层厚,电镀锌成本低。<FONT face="Times New Roman"> </FONT>吹氧焊管:用作炼钢吹氧用管,一般用小口径的焊接钢管,规格由<FONT face="Times New Roman">3/8</FONT>寸<FONT face="Times New Roman">-2</FONT>寸八种。用<FONT face="Times New Roman">08</FONT>、<FONT face="Times New Roman">10</FONT>、<FONT face="Times New Roman">15</FONT>、<FONT face="Times New Roman">20</FONT>或<FONT face="Times New Roman">Q195-Q235</FONT>钢带制成。为防蚀,有的进行渗铝处理。<FONT face="Times New Roman"> </FONT>电线套管:也是普通碳素钢电焊钢管,用在混凝土及各种结构配电工程,常用的公称直径从<FONT face="Times New Roman">13-76mm</FONT>。电线套套管壁较薄,大多进行涂层或镀锌后使用,要求进行冷弯试验。<FONT face="Times New Roman"> </FONT>公制焊管:规格用无缝管形式,用外径<FONT face="Times New Roman">*</FONT>壁厚毫米表示的焊接钢管,用普通碳素钢、优质碳素钢或普能低合金钢的热带、冷带焊接,或用热带焊接后再经冷拨方法制成。公制焊管分普能和薄壁、普通用作结构件,如传动轴,或输送流体,薄壁用来生产家具、灯具等,要保证钢管强度和弯曲试验。<FONT face="Times New Roman"> </FONT>托辊管:用于带式输送机托辊电焊钢管,一般用<FONT face="Times New Roman">Q215</FONT>、<FONT face="Times New Roman">Q235A</FONT>、<FONT face="Times New Roman">B</FONT>钢及<FONT face="Times New Roman">20</FONT>钢制造,直径<FONT face="Times New Roman">63.5-219.0mm</FONT>。对管弯曲度、端面要与中心线垂直、椭圆度有一定要求,一般进行水压和压扁试验。<FONT face="Times New Roman"> </FONT>变压器管:用于制造变压器散热管和其它热交换器,采用普通碳素钢制造,要求进行压扁、扩口、弯曲、液压试验。钢管以定尺或倍尺交货,对钢管弯曲度有一定要求。<FONT face="Times New Roman"> </FONT>异型管:由普通碳结结构钢及<FONT face="Times New Roman">16Mn</FONT>等钢带焊制的方形管、矩形管、帽形管、空胶钢门窗用钢管,主要用作农机构件、钢窗门等。<FONT face="Times New Roman"> </FONT>电焊薄壁管:主要用来制作家具、玩具、灯具等。近年来不锈钢带制作的薄壁管应用很广,高级家具、装饰、栏栅等。<FONT face="Times New Roman"> </FONT>螺旋焊管:是将低碳碳素结构钢或低合金结构钢钢带按一定的螺旋线的角度(叫成型角)卷成管坯,然后将管缝焊接起来制成,它可以用较窄的带钢生产大直径的钢管。螺旋焊管主要用于石油、天然气的输送管线,其规格用外径<FONT face="Times New Roman">*</FONT>壁厚表示。螺旋焊管有单面焊的和双面焊的,焊管应保证水压试验、焊缝的抗拉强度和冷弯性能要符合规定。</P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt">文章全部转载完。</P>
Re: 钢铁知识大全---搞机械的人士必须的知识
长知识了~!Re: 钢铁知识大全---搞机械的人士必须的知识
谢谢,不过为什么不做成附件?Re: 钢铁知识大全---搞机械的人士必须的知识
不错,不过作成文件就更加方便了Re: 钢铁知识大全---搞机械的人士必须的知识
楼主有qq吗!想和你交流一下
楼主讲的东西很有用,同时,如果加上一些具体应用的比较就好了,比如有些地方用热轧不能用冷扎的。希望楼主能够解惑
