水切割加工是否适合您的需要?
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; tab-stops: 27.0pt"><B><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial">水刀与<SPAN style="mso-bidi-font-style: italic">其它热态切割相比具有如下优点</SPAN></SPAN></B><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-style: italic">:</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt; FONT-FAMILY: Arial"><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 24pt; mso-char-indent-count: 2.0; mso-char-indent-size: 12.0pt; tab-stops: 36.75pt"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial">从切割效果上讲,水切割可达到半精加工水平</SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial">。如果切割半精加工零件,它切割出来就无需后道工序,如千分尺尺架,连杆体等。从切割效率上,它不如火焰、等离子切割快,但火焰切割有后道工序问题,如退火、机械加工,去毛刺等。</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt; FONT-FAMILY: Arial"><o:p></o:p></SPAN></P>
<P class=MsoBodyTextIndent3 style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; tab-stops: 36.75pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial">热态切割会在切口处造成烧伤和熔化,此外在受热范围内还会产生应力、微裂纹。</SPAN><SPAN lang=EN-US style="FONT-FAMILY: Arial"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 24pt; mso-char-indent-count: 2.0; mso-char-indent-size: 12.0pt; tab-stops: 10.5pt"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial">而水切割是冷态切割,相比之下有以下好处:</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt; FONT-FAMILY: Arial"><o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 24pt; mso-char-indent-count: 2.0; mso-char-indent-size: 12.0pt; tab-stops: 10.5pt"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial">⑴</SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: Arial"> </SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial">对切口不会造成烧伤;不会产生融化;不会造成硬化;不会造成变形;不会出现焊瘤;不会产生有毒气体。</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt; FONT-FAMILY: Arial"><o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 24pt; mso-char-indent-count: 2.0; mso-char-indent-size: 12.0pt; tab-stops: 10.5pt"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial">⑵</SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: Arial"> </SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial">不会对工件产生直接的压力;可以高速精确切割;可以切割复杂形状、极小直径和尖角;切缝小、材料损耗少;高质量套切;在材料任何位置都可以下刀;加工简便、快捷。</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt; FONT-FAMILY: Arial"><o:p></o:p></SPAN></P><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-font-kerning: 1.0pt; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-language: AR-SA; mso-fareast-language: ZH-CN; mso-ansi-language: EN-US"> ⑶</SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: Arial; mso-font-kerning: 1.0pt; mso-bidi-language: AR-SA; mso-fareast-language: ZH-CN; mso-ansi-language: EN-US; mso-fareast-font-family: 宋体"> </SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-font-kerning: 1.0pt; mso-bidi-font-family: Arial; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-language: AR-SA; mso-fareast-language: ZH-CN; mso-ansi-language: EN-US">无论是小工件还是大工件,无论是单件还是小批量或大批量,都可以加工。</SPAN>
Re: 水切割加工是否适合您的需要?
请教:能切多厚的钢板,同时需要多大的功率,能耗比氧割或等离子大吗?效率能慢多少呢?谢谢答复Re: 水切割加工是否适合您的需要?
<P>现在国产水刀切割钢板时,能够保证质量的切割厚度为30—40mm,最后可达50mm。</P><P>现在国产水刀主流功率在22Kw。效率没有氧割和等离子快,但切割质量要远高于它们。例如:水刀切割40mm厚度钢板的速度大概在10mm/min左右。</P>
Re: 水切割加工是否适合您的需要?
一般的工厂可以用吗,对这个我还不是很清楚,第一次听说,我们单位用的都是等离子,感觉切的不是很好,况且小的不能切Re: 水切割加工是否适合您的需要?
<P> 可以用啊,切割质量比等离子好,不过效率没有等离子高,但等离子切割后一般都有后道工序,而水切割的切割质量要好很多,一般没有后道工序,就看怎么取舍了。</P><P> 由于水切割是冷态切割,切割过程中不会对工件产生影响。即使小圆弧、小尖角都可以切割(切割缝隙1.2mm左右)。</P>
<P> 可以说说你们切割的产品的情况,尺寸、形状、质量要求等。</P>
Re: 水切割加工是否适合您的需要?
水切割是什么原理呀,能加工盲孔吗,加工时会不会产生很大的力量,工件要加的很紧吗Re: 水切割加工是否适合您的需要?
<P><FONT style="BACKGROUND-COLOR: #efefef">超高压磨料水切割的原理: 通过增压器将水压增至比如300Mpa的压力,通过能量转换器将压力能转化为动能,磨料粒子在高速水流的带动下形成切割能力而射向被切割物。相当于是个水砂轮。</FONT></P><P><FONT style="BACKGROUND-COLOR: #efefef">由于水切割是垂直射向工件的,所以横向力很小,只需要一般夹紧即可。有些工件利用本身的自重即可,如:20mm钢板等,只需定位不需夹紧。</FONT></P>
Re: 水切割加工是否适合您的需要?
<P><FONT style="BACKGROUND-COLOR: #efefef">那相对于激光切割呢。</FONT></P>Re: 水切割加工是否适合您的需要?
<P> </P><P> 水切割属于冷态切割,无污染,无热变形,无加工硬化现象等,不会对加工物产生任何影响,不会破坏材料组织。而热态切割(包括激光切割)会在切口处造成烧伤和熔化,还会在受热范围内产生热应力,还会有焊瘤等现象。</P>
<P> 但水切割的切割效率没有激光切割快。</P>
<P> 一个实际情况:需要切割类似齿尖形状的小尖角,用激光切割很容易因为受热而变形,而水切割就可以很好地解决这个问题。</P>
<P> </P>
