弹簧钢的热处理
<FONT color=#000000><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 176pt; mso-char-indent-count: 11.0; mso-char-indent-size: 16.0pt"><SPAN style="FONT-SIZE: 16pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">弹</SPAN><SPAN style="FONT-SIZE: 16pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"> </FONT></SPAN><SPAN style="FONT-SIZE: 16pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">簧</SPAN><SPAN style="FONT-SIZE: 16pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"> </FONT></SPAN><SPAN style="FONT-SIZE: 16pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">钢</SPAN><SPAN lang=EN-US style="FONT-SIZE: 16pt; mso-bidi-font-size: 12.0pt"><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 176pt; mso-char-indent-count: 11.0; mso-char-indent-size: 16.0pt"><SPAN lang=EN-US style="FONT-SIZE: 16pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"> <o:p></o:p></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.5pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">弹簧钢的特点</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">—</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">弹簧主要在动载荷下工作</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">即在冲击、振动的条件下</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">或在交变应力作用下工作</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">利用弹性变形来吸收冲击能量</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">起缓冲作用。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.5pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">由于弹簧经常承受振动和长期在享变应力作用下工作</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">主要是疲劳破坏</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">故弹簧钢必须具有高的弹性极限和高疲劳极限。此外</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">还应有足够的韧性和塑性</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">以防止在冲击力作用下突然脆断。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.5pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">在工艺性论方面</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">弹簧钢应具有较好的淬透性和低的过热、脱碳敏感性。降低弹簧表面粗糙度能提高疲劳寿命。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.5pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">为了获得所需的性能</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">弹簧钢必须具有较高的含碳量。碳素弹簧钢的含碳量在</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">0.6-0.9</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%之间</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">由于碳素弹簧钢的淬透性差</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">故只用于制造截面尺寸不超过</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">10-15mm</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的弹簧。对于截面尺寸较大的弹簧</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">必须采用合金弹簧钢。合金弹簧钢碳含量在</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">0.45-0.75</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%之间</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">加入的合金元素有</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">Mn ,Si ,W ,V ,Mo</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">等。它们的主要作用是提高淬透性和回火稳定性</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">强化铁素体和细化晶粒</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">有效地改善弹簧钢的力学性能</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">其中</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">Cr ,W ,Mo</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">还能提高钢的高温强度。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.5pt"><SPAN lang=EN-US><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 31.5pt; mso-char-indent-count: 3.0; mso-char-indent-size: 10.5pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">在热状态下成型的弹簧</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">(</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">直径或厚度一般在</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">10mm</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">以上</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">)</FONT></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">在冷状态下成型的弹簧</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">(</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">直径或厚度一般在</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">10mm</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">以下</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">)</FONT></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">热成型弹簧的热处理工艺</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">--</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">用这种方法成型弹簧多数是将热成型和热处理结合在一起进行的</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">而螺旋弹簧则大多数是在热成型后再进行热处理。这种弹簧钢的热处理方式是淬火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">+</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">中温回火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">热处理后组织为回火托氏体。这种组织的弹性极限和屈服极限高</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">并有一定的韧性。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">冷成型弹簧的热处理工艺</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">--</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">对于用冷轧钢板、钢带或冷拉钢丝制成的弹簧</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">由于冷塑性变形使材料强化</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">己达到弹簧所要求的性能。故弹簧成型后只需在</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">250C</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">左右范围内</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">保温</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">30min</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">左右的去应力处理</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">以消除冷成型弹簧的门应力</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">并使弹簧定型即可。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21.75pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"> 耐热弹簧钢的热处理</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">--</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">内燃机的气阀弹簧是在较高温度下工作</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">有的还存在腐蚀性气氛</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">因此必须选用特殊的弹簧钢和合适的热处理规范。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21.75pt"><SPAN lang=EN-US><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">弹簧淬火时常见的缺陷及防止措施</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(1)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">脱碳</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">(</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">降低使用寿命</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">)--1</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、采用盐浴炉或拄制气氛加热炉加热。</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">2</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、采用快速加热工艺。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(2)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">淬火后硬度不足</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">非马氏体数量较多</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">心部出现铁素体</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">(</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">产全残余变形</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">降低使用寿命</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">)--1</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、选用淬透性较好的材料。</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">2</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、改善淬火冷却剂的冷却能力。</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">3</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、弹簧进入冷却剂的温度应控制在</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">Ar3</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">以上。</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">4</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、适当提高淬火加热温度。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(3)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">过热</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">(</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">脆性增加</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">)--1</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、严格控制成型及淬火加热温度。</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">2</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、加强淬火时的金相检验。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(4)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">开裂</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">(</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">脆性增加</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">严重降低使用寿命</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">)--1</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、控制淬火加热温度。</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">2</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、淬火时冷到</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">250-300C</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">时</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">取出空冷。</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">3</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、及时回火</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">提高弹簧质量的措施</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(1)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">形变热处理</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">--</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">将钢的变形强化与热处理强化两者结合起来</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">以进一步提高钢的强度和韧性。形变热处理有高、中、低温之分。高温形变热处理是在稳远的奥氏体状态下产生形变后立即淬火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">也可与锻造或热轧结合起来</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">即热成型后立即淬火。形变热处理己应用于汽车板簧生产中。</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">(60Si2Mn)</FONT></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(2)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">弹簧的等温淬火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">--</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">对于直径较小或透透性足够的弹簧可采用等温淬火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">它不仅能减少变形</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">而且还能提高强韧性</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">在等温淬火后最好再进行一次回火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">可提高弹性极限</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">回火温度与等温淬火温度相同。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(3)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">弹簧的松弛处理</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">--</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">弹簧长时间在外力作用下工作</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">由于应力松弛的结果会产生微量的永久</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">(</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">塑性</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">变形</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">特别是高温工作的弹簧</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">在高温下应力松弛现象更为严重</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">使弹簧的精度降低</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">这对于一般精密弹簧是不允许的。因此</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">这类弹簧在淬火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">回火后应进行松弛处理</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">--</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">对弹簧预先加载荷</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">使其变形量超过弹簧工作时可能产生的变形量。然后在高于工作温度</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">20C</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的条件下加热</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">保温</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">8-24h</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(4)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">低温碳氮共渗</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">--</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">采用回火与低温碳氮共渗</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">(</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">软氮化</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">相结合的工艺</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">能显著提高弹簧的疲劳寿命及耐蚀性</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">此工艺多用于卷簧。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21.75pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">(5)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">喷丸处理</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">--</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">划痕、折叠、氧化脱碳等表面缺陷往往会成为弹簧工作时应力集中的地方和疲劳断裂源。若用细小的钢丸高速喷打弹簧表面</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">不仅改善弹簧表面质量</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">提高表面强度</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">并使表面处于压应力状态</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">从而提高弹簧疲劳强度和使用寿命。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">操作注意事项</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(1)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">热处理前检查表面是否有脱碳、裂纹等缺陷。这些表面缺陷将严重地降低弹簧的疲劳极限。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(2)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">淬火加热应特别注意防止过热和脱碳</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">做好盐浴脱氧</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">控制炉气气氛</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">严格控制加热温度与时间</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(3)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">为减少变形</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">弹簧在加热时的装炉方式</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">夹具形式和冷却时淬入冷却方法。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"> </SPAN></FONT><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">(4)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">淬火后要尽快回火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">加热要尽量均勺。回火后快冷能防止回火脆性和造成表面压应力</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">提高疲劳强度。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">质量检查</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">热处理前</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">--(1)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">钢材的轧制表面往往就是制成弹簧后的表面</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">故不应有裂纹、折叠、斑疤、发纹、气泡、夹层和压入的氧化皮等。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(2)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">表面脱碳会显著降什弹簧的疲劳强度</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">应按规定检验脱碳层的深度。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">热处理后</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">--(1)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">肉眼或低倍放大镜观察弹簧表的不应有裂纹、腐蚀麻点和严重的淬火变形。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(2)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">硬度及其均匀性符合规定。大量生产时</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">允许用锉刀抽检硬度</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">但必须注意锉痕位置应不影响弹簧的最后精度。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>(3)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">金相组织应是托氏体或托氏体和索氏体的混合组织。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 69pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">(4)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">板簧装配后</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">通常还要进行工作载荷下的永久变形以及静载挠度试验。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 69pt"><SPAN lang=EN-US><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>各种弹簧钢的热处理规范及硬度要求</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">钢号</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">淬火温度</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">淬火介质</SPAN><SPAN style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"> </FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">硬度要求</SPAN><SPAN style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"> </FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">回火温度</SPAN><SPAN style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"> </FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">冷却介质</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">硬度要求</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">应用范围</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman">65<SPAN style="mso-spacerun: yes"> </SPAN>780-830<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">水或油</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>400-600<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">线径小于</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman">12-15mm</FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的螺旋弹簧、弹簧垫圈</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman">65Mn<SPAN style="mso-spacerun: yes"> </SPAN>810-830<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">油或水</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>>60<SPAN style="mso-spacerun: yes"> </SPAN>370-400<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">水</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>42-50<SPAN style="mso-spacerun: yes"> </SPAN>5-10mm</FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的板簧片及</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman">7-10mm</FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的卷簧</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman">50CrV<SPAN style="mso-spacerun: yes"> </SPAN>850-870<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">油</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>>58<SPAN style="mso-spacerun: yes"> </SPAN>400-55 <SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">水</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>45-50<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">截面较大和较重要的板簧片及螺旋弹簧</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"> <o:p></o:p></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman">50CrV<SPAN style="mso-spacerun: yes"> </SPAN>850-870<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">油</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>>58<SPAN style="mso-spacerun: yes"> </SPAN>370-420<SPAN style="mso-spacerun: yes"> </SPAN>45-52<SPAN style="mso-spacerun: yes"> </SPAN>300C</FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">以下工作的高温弹簧</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"> <o:p></o:p></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman">60Si2MnA<SPAN style="mso-spacerun: yes"> </SPAN>860-880<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">油</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>>60<SPAN style="mso-spacerun: yes"> </SPAN>500-520<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">水</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>HB363-444<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">厚度</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman">8-12mm</FONT></SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的板簧片</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"> <o:p></o:p></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><FONT face="Times New Roman"> <o:p></o:p></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.5pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">耐热弹簧钢的材料选用和最高使用温度的热处理规范</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">钢号</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">最高使用温度</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">热成型</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">(</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">度</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">)<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">淬火温度</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">回火温度</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">50CrVA<SPAN style="mso-spacerun: yes"> </SPAN>300<SPAN style="mso-spacerun: yes"> </SPAN>880-900<SPAN style="mso-spacerun: yes"> </SPAN>850-870</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">油</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>430-500</FONT></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">4Cr13<SPAN style="mso-spacerun: yes"> </SPAN>400<SPAN style="mso-spacerun: yes"> </SPAN>850-1050<SPAN style="mso-spacerun: yes"> </SPAN>980-1050</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">空冷</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"> 540-560</FONT></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">冷拉</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">18-8</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">型不锈钢丝</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>400<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">冷卷</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">去应力回火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">400C,15-60min</FONT></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">W18Cr4V<SPAN style="mso-spacerun: yes"> </SPAN>600<SPAN style="mso-spacerun: yes"> </SPAN>1000-1200<SPAN style="mso-spacerun: yes"> </SPAN>1280-1290</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">油或空冷</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>700</FONT></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">60Si2MnA<SPAN style="mso-spacerun: yes"> </SPAN>250<SPAN style="mso-spacerun: yes"> </SPAN>880-900<SPAN style="mso-spacerun: yes"> </SPAN>860-880</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">油</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>350</FONT></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>常用弹簧钢的等温淬火规范</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">钢号</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">加热温度</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">等温淬火温度</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">等温保持时间</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">硬度</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">HRC</FONT></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>T10A<SPAN style="mso-spacerun: yes"> </SPAN>800+-10<SPAN style="mso-spacerun: yes"> </SPAN>250-360<SPAN style="mso-spacerun: yes"> </SPAN><SPAN style="mso-spacerun: yes"> </SPAN>10-30<SPAN style="mso-spacerun: yes"> </SPAN>40-53</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>65<SPAN style="mso-spacerun: yes"> </SPAN>820+-10<SPAN style="mso-spacerun: yes"> </SPAN>320-340<SPAN style="mso-spacerun: yes"> </SPAN>15-30<SPAN style="mso-spacerun: yes"> </SPAN>46-48</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>65Mn<SPAN style="mso-spacerun: yes"> </SPAN>820+-10<SPAN style="mso-spacerun: yes"> </SPAN>270 / 320-340<SPAN style="mso-spacerun: yes"> </SPAN>15-30<SPAN style="mso-spacerun: yes"> </SPAN>52-54 / 46-48</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>50CrVA<SPAN style="mso-spacerun: yes"> </SPAN>850+-10<SPAN style="mso-spacerun: yes"> </SPAN>300<SPAN style="mso-spacerun: yes"> </SPAN>30-45<SPAN style="mso-spacerun: yes"> </SPAN><SPAN style="mso-spacerun: yes"> </SPAN>52</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><FONT face="Times New Roman" size=3>60Si2MnA<SPAN style="mso-spacerun: yes"> </SPAN>87+-10<SPAN style="mso-spacerun: yes"> </SPAN>280<SPAN style="mso-spacerun: yes"> </SPAN>30-45<SPAN style="mso-spacerun: yes"> </SPAN>52</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.5pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">50CrV</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">钢气阀弹簧低温碳氮共渗</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">(</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">软氮化</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">)</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">与普通热处理后疲劳性能比较</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">热处理工艺</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">断裂应变周次</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman"> </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">断裂后残余变形</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">(mm)<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">室内耐大气腐蚀试验</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">860C</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">油淬</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,420C</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">回火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">1h<SPAN style="mso-spacerun: yes"> </SPAN>1.78*10000<SPAN style="mso-spacerun: yes"> </SPAN>2.4<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">发黑后未上油</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,14</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">天后出现锈斑</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">860C</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">油淬</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,480C</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">软氮化</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">3h<SPAN style="mso-spacerun: yes"> </SPAN>>=100*10000<SPAN style="mso-spacerun: yes"> </SPAN>0.2<SPAN style="mso-spacerun: yes"> </SPAN>850</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">天以上未生锈</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">860C</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">油淬</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">,510C</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">软氮化</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">3h<SPAN style="mso-spacerun: yes"> </SPAN>>=100*10000<SPAN style="mso-spacerun: yes"> </SPAN>0.6<SPAN style="mso-spacerun: yes"> </SPAN>850</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">天以上未生锈</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT size=3></FONT></SPAN></SPAN> </P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">例</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">;<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">压缩螺旋弹簧</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes"> </SPAN>50CrV<SPAN style="mso-spacerun: yes"> </SPAN>43-50HRC<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">外径¢</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">31.5<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">线径¢</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">3.5<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">总高度</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">50</FONT></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 63pt; TEXT-INDENT: -63pt; mso-char-indent-count: -6.0; mso-char-indent-size: 10.5pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">工艺流程</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"> ;<SPAN style="mso-spacerun: yes"> </SPAN></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">冷卷</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">—</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">定型处理</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">—</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">切断修正</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">—</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">淬火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">—</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">矫正回火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">—</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">检验修正</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">—</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">最后回火</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">—</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">检验、喷砂、表面处理。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 63pt; TEXT-INDENT: -63pt; mso-char-indent-count: -6.0; mso-char-indent-size: 10.5pt"><SPAN lang=EN-US><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 63pt; TEXT-INDENT: -63pt; mso-char-indent-count: -6.0; mso-char-indent-size: 10.5pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">以上资料来源于</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><<</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">金属热处理工手册</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">>></FONT></SPAN></FONT></P>
<P></FONT> </P>
Re: 弹簧钢的热处理
goodRe: 弹簧钢的热处理
我的工作与机械行业密切相关,但是相关技术知识几乎空白,谢谢楼主的无私奉献 我正好在找这个资料啊,感谢楼主奉献 谢谢楼主了:handshake 还是楼主有爱心,两种版本都给提供了。{:soso_e179:} 正需要呢,谢谢楼主呢 很详细 谢谢楼主了楼主 想问一个简单的问题 弹簧的用的上淬火机床吗?
