atongge 发表于 2006-10-16 09:27:16
如何解决齿轮出棱问题?
<P><FONT style="BACKGROUND-COLOR: #efefef"><SPAN style="FONT-SIZE: 9pt; COLOR: #404040; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana; mso-bidi-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">。图</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: #404040; FONT-FAMILY: Verdana; mso-bidi-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-fareast-font-family: 宋体">a</SPAN><SPAN style="FONT-SIZE: 9pt; COLOR: #404040; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana; mso-bidi-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">为齿面出棱、图</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: #404040; FONT-FAMILY: Verdana; mso-bidi-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-fareast-font-family: 宋体">b</SPAN><SPAN style="FONT-SIZE: 9pt; COLOR: #404040; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana; mso-bidi-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">为齿形不对称、图</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: #404040; FONT-FAMILY: Verdana; mso-bidi-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-fareast-font-family: 宋体">c</SPAN><SPAN style="FONT-SIZE: 9pt; COLOR: #404040; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana; mso-bidi-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">为齿形角误差、图</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: #404040; FONT-FAMILY: Verdana; mso-bidi-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-fareast-font-family: 宋体">d</SPAN><SPAN style="FONT-SIZE: 9pt; COLOR: #404040; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana; mso-bidi-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">为齿面上的周期性误差、图</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: #404040; FONT-FAMILY: Verdana; mso-bidi-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-fareast-font-family: 宋体">e</SPAN><SPAN style="FONT-SIZE: 9pt; COLOR: #404040; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana; mso-bidi-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">为齿轮根切<SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: #404040; FONT-FAMILY: Verdana; mso-bidi-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-fareast-font-family: 宋体"><?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" o:preferrelative="t" o:spt="75" coordsize="21600,21600"> <v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><v:path o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></v:path><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape id=_x0000_i1025 style="WIDTH: 270pt; HEIGHT: 215.25pt" type="#_x0000_t75" alt=""><v:imagedata o:href="http://www.wxit.edu.cn/jpkc/Jzgy/Wlkc/html/No9/9-6.gif" src="file:///C:\DOCUME~1\atongge\LOCALS~1\Temp\msohtml1\01\clip_image001.gif"></v:imagedata></v:shape></SPAN></SPAN></FONT></P>
桂林 发表于 2006-10-16 09:28:04
Re: 如何解决齿轮出棱问题?
图在哪啊?
atongge 发表于 2006-10-16 09:44:30
Re: 如何解决齿轮出棱问题?
图上传不了哦~~郁闷
atongge 发表于 2006-10-16 09:46:18
Re: 如何解决齿轮出棱问题?
这个是图
ydf4692 发表于 2006-10-18 23:02:13
Re: 如何解决齿轮出棱问题?
(a)产生的原因是:滚刀刀齿沿圆周等分性不好,这主要是制造和复磨滚刀时产生的误差所致;加一个主要原因是滚刀安装时刀杆径向跳动超差,安装后轴向窜动超差。
(b)滚齿前滚刀对中不好是引起齿形不对称的主要原因。
(c)与滚刀的刃磨有关,刃磨不好时会出现前角(正或负),前角为正时齿形角变小,切出的齿形齿顶变肥;前角为负时齿形角变大,切出的齿形齿顶变瘦。
(d)滚刀安装后的径向跳动超差和旋转中的轴向窜动,机床分度蜗轮副中,分度蜗杆的径向跳动和轴向窜动都是产生周期性的误差因素。
atongge 发表于 2006-10-19 16:34:01
Re: 如何解决齿轮出棱问题?
谢谢,我注意这几个方面再试试,但不知道滚刀去哪复磨才能保证质量呢?我都还是在上海工具厂磨的有些是就是在们这加工点魔的
ydf4692 发表于 2006-10-20 21:41:42
Re: 如何解决齿轮出棱问题?
滚刀磨后是要经过计量的,如无计量设备可采用试切零件办法。
齿轮家族 发表于 2007-2-16 12:07:21
Re: 如何解决齿轮出棱问题?
重工、汉工修磨刀具都比较好。我们的刀具都在重工制作和修磨。
zht_udb 发表于 2007-2-25 12:45:15
Re: 如何解决齿轮出棱问题?
<P>造成齿轮出棱的原因:1、刀具的质量问题;2、加工过程质量问题;3、刀具修磨质量问题。</P>
<P>解决的办法:1、控制外购刀具质量,选择正规厂家的刀具,如哈工、上工、汉工、重工。</P>
<P>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 2、重新校正刀杆的窜动量和跳动量,对刀要对工件的中心。</P>
<P>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 3、修磨滚刀时,根据加工齿轮的精度,确定机床修磨精度。</P>
cuiyang 发表于 2009-12-16 13:02:50
我也学习一下
查看完整版本: 如何解决齿轮出棱问题?
