menwei09 发表于 2010-1-29 20:51:09
ANSYS经典实例汇集(共72个例子)
1.ANSYS SOLID65 环向布置钢筋的例子.............................................................................4
2.混凝土非线性计算实例(1)- MISO 单压........................................................................6
3.混凝土非线性计算实例(2)- MISO 约束压....................................................................7
4.混凝土非线性计算实例(3)- KINH 滞回......................................................................10
5.混凝土非线性计算实例(4)- KINH 压-拉裂................................................................12
6.混凝土非线性计算实例(5)...........................................................................................13
7.混凝土非线性计算实例(6)...........................................................................................15
8.混凝土非线性计算实例(7)- MISO 滞回......................................................................17
9.混凝土非线性计算实例(8)...........................................................................................19
10.混凝土非线性计算实例(9)-梁平面应力...................................................................21
11.四层弹簧-质点模型的地震分析...................................................................................23
12.悬臂梁地震分析...............................................................................................................49
13.用 beam 54 单元描述变截面梁的例子...........................................................................73
14.变截面梁实例...................................................................................................................74
15.拱桥浇筑过程分析-单元生死应用实例..........................................................................75
16.简支梁实体与预应力钢筋分析实例................................................................................76
17. 简单的二维焊接分析-单元生死实例.........................................................................78
18.隧道开挖(三维)的命令流............................................................................................85
19.岩土接触分析实例..........................................................................................................102
20.钢筋混凝土管的动力响应特性分析实例......................................................................110
21.隧道模拟开挖命令流(入门)......................................................................................117
22.螺栓连接的模拟实现问题..............................................................................................120
23.道路的基层、垫层模量与应力之间的关系..................................................................130
23.滞回分析..........................................................................................................................152
24.模拟某楼层浇注.............................................................................................................154
25.在面上施加移动的面力.................................................................................................156
27.在任意面施加任意方向任意变化的压力.....................................................................160
28.预紧分析.........................................................................................................................161
29.几何非线性+塑性+接触+蠕变....................................................................................163
30.埋设在地下的排水管道.................................................................................................168
32.幕墙企业玻璃简化计算.................................................................................................173
33.等截面杆单元生死应用实例.........................................................................................189
34.梁板建模联系.................................................................................................................190
36.简单的例子-如何对结构的振动控制分析.................................................................193
37.模态分析结果的输出实例.............................................................................................195
38.火车过桥动态加载实例(部分).................................................................................197
39.悬索结构的找形和计算的例题.....................................................................................214
40.陶瓷杆撞击铝板的例子.................................................................................................219
41.求反作用力的APDL 命令法........................................................................................222
42.LS-DYNA 实例(部分)..............................................................................................223
43.路面分层填筑对路基的影响.........................................................................................224
44.一个例子(含地震影响,求振兴与频率).................................................................228
45.接触面上的压力总和.....................................................................................................232
46.施加位置函数荷载.........................................................................................................236
----------------------- Page 3-----------------------
47.非线性分析考虑刚度退化.............................................................................................237
48.一个圆形水池的静力分析.............................................................................................238
49.ANSYS 中混凝土模式预应力模拟的算例......................................................................239
50.悬臂梁受重力作用发生大变形求其固有频率.............................................................241
51.循环对称结构模态分析.................................................................................................243
52.三角平台受谐波载荷作用的结构响应.........................................................................245
53.三角平台受一地震谱激励的应力分布和支反力.........................................................247
54.三角平台受时程载荷作用的应力分布和变形过程.....................................................249
55.经典层合板理论.............................................................................................................251
56.定易圆轨迹的例子.......................................................................................................258
57.模拟门式刚架施工-单元生死...................................................................................258
58.钢筋混凝土整体式模型例子.......................................................................................261
59.在荷载步之间改变材料属性例子...............................................................................263
60.含预应力的特征值屈曲计算.......................................................................................264
61.振型叠加计算及工况组合例子...................................................................................266
62.柱子稳定分析算(预应力,特征值屈曲,初始缺陷)...........................................269
63. module MConcrete !混凝土模板 ............................................................................272
64.混凝土开裂实例.............................................................................................................280
65.螺栓网格划分...............................................................................................................281
66.自由液面的土石坝平面渗流分析...............................................................................282
67.导出刚度矩阵...............................................................................................................286
68.某混凝土拱坝工程施工期及运行期温度场仿真分析...............................................287
69.移动温度荷载计算.......................................................................................................294
70.SHSD 用于壳-实体装配实例An .................................................................................296
71.ansys 显示-隐式-回弹分析实例.........................................................................300
72.工况组合的经典例子...................................................................................................315
guxiangjun2008 发表于 2010-2-2 14:09:33
下载了有时间了 复习一下:lol
yupeng0603 发表于 2010-2-5 22:21:16
:handshake
很有用的东东呢
滚刀鱼 发表于 2010-2-7 09:05:01
xie xiel e a
hxydyh 发表于 2010-2-14 22:08:58
很有用的东东
yumingxing 发表于 2010-2-24 21:01:46
恩,很不错哦
davidmei 发表于 2010-3-14 10:15:10
非常经典的资料,感谢楼主
rzy_zh 发表于 2010-3-18 08:54:30
下载了,感谢楼主
cquxl 发表于 2010-3-24 09:57:45
谢谢楼主 下来看看
xiongciyuan1013 发表于 2010-3-31 12:12:31
谢谢楼主。。。
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: ANSYS经典实例汇集(共72个例子)
