求徐州锻压设备厂4柱500T压力机液压油路图纸
徐州锻压设备厂4柱500T压力机液压油路图纸项目单位型号规格YX32-500YX32-500B
YX32-500FYX32-500GYX32-500S公称力kN50005000500050005000顶出力kN10001000100010001000回程力kN600100010001000600滑块行程mm9009001000900900顶出行程mm350350400350350最大开口高度mm15001500160018001500滑块行程速度空程下行mm/s100100300100150工作101035>256~16回程808030080130顶出行程速度顶出mm/s80807080130退回240240220240195工作台尺寸左右mm1400/170020002500/315014001400前后1400/150014201500/160014001400立柱中心距左右mm16002200280016001600前后11001100116011001100机器外形尺寸左右mm38004500410038402660前后35003500230039001900地面上高52205220650052205400电动机功率kW45.545.59218044
是09年3月产的
