几种停机的危机程度,应该怎么理解?
Severity is the extent in which a components impacts the channel business planCritical is an intolerable failure that results in a direct impact on the channel business plan
Non-critical is a tolerable failure that results in a indirect impact on the channel business plan
Tolerable means that it is an acceptable failure but requires further analysis to define maintainability
Intolerable means that it is not an acceptable failure and requires analysis to define failure prevention/prediction
是‘卡农’还是‘撒卡’?我是‘塞牙’!啊点哪的‘僧抖四’
