oy87188 发表于 2023-11-4 18:14:37
SW关于输出曲面点阵到txt文档的宏代码
尊敬的各位大佬,本人是SW使用的小白,最近在调试SW的宏代码时,想通过宏代码将曲面上的点阵输出到txt中,从而方便后续处理。但是遇到了如下的问题:显示对应变量未定义,还望各位大佬多多指点一二?:lol:lol
附上对应的代码如下:(压缩包内为swp文件)
' 输出曲面上某些点到Txt文件中
Sub main()
    Dim swApp As SldWorks.SldWorks
    Dim myModel As SldWorks.ModelDoc2
    Dim mathUtils As SldWorks.MathUtility
    Dim nStart As Single
      nStart = Timer
    Set swApp = Application.SldWorks
    Set myModel = swApp.ActiveDoc
    Set mathUtils = swApp.GetMathUtility()
    ' 以下遍历22x22个投影点
    Dim i As Integer
    Dim j As Integer
    For i = 0 To 21
    For j = 0 To 21
    ' 预先指定一个被投影面
    Dim mySelMgr As SldWorks.SelectionMgr
    Dim selObj As Object
    Dim faceToUse As SldWorks.Face2
    Dim surfaceToUse As SldWorks.Surface
    Dim selCount As Long
    Dim selType As Long
    Set mySelMgr = myModel.SelectionManager
      selCount = mySelMgr.GetSelectedObjectCount2(0)
      If (selCount > 0) Then
      selType = mySelMgr.GetSelectedObjectType3(1, 0)
    Set selObj = mySelMgr.GetSelectedObject6(1, 0)
      If (selType = SwConst.swSelFACES) Then
      Set faceToUse = selObj
      End If
    End If
    ' 定义投影向量
    Dim basePoint(0 To 2) As Double, rayDir(0 To 2) As Double
    Dim vBasePoint As Variant, vVector As Variant
    Dim rayPoint As SldWorks.MathPoint, rayVector As SldWorks.MathVector
    Dim intersectPt As SldWorks.MathPoint
    Dim vPoint As Variant, vPoint2 As Variant
    Dim xPt As Double, yPt As Double, zPt As Double
    ' 先对曲面的情况进行投影; First try the face
      If Not faceToUse Is Nothing Then
      basePoint(0) = i * 0.125 '
      basePoint(1) = j * 0.125 '
      basePoint(2) = 1#
      vBasePoint = basePoint
    Set rayPoint = mathUtils.CreatePoint(vBasePoint)
      rayDir(0) = 0#
      rayDir(1) = 0#
      rayDir(2) = -1#
      vVector = rayDir
    Set rayVector = mathUtils.CreateVector(vVector)
    Set intersectPt = faceToUse.GetProjectedPointOn(rayPoint, rayVector)
    If Not intersectPt Is Nothing Then
      vPoint = intersectPt.ArrayData
      xPt = vPoint(0)
      yPt = vPoint(1)
      zPt = vPoint(2)
      清单输出窗口.LIST.Text = 清单输出窗口.LIST.Text & Format(xPt * 1000, "##0.0#####") & " ,"
      清单输出窗口.LIST.Text = 清单输出窗口.LIST.Text & Format(yPt * 1000, "##0.0#####") & " ,"
      清单输出窗口.LIST.Text = 清单输出窗口.LIST.Text & Format(zPt * 1000, "##0.0#####") & " " & vbCrLf
    Else
      清单输出窗口.LIST.Text = 清单输出窗口.LIST.Text & Format(zPt * 1000, "##0.0#####") & " " & vbCrLf    '(j * 125, "##0.0#####") & " , 0" & "   " & vbCrLf '控制是否输出未投影到曲面上的点位 " No face hit point."
      End If
    End If
    Next j
    Next i
    清单输出窗口.计算耗用时间.Text = Round(Timer) - Round(nStart) & "秒"
    清单输出窗口.Show
End Sub
Public Sub Delayms(lngTime As Long) '延时程序调用-测试时用
Dim StartTime As Single
Dim CostTime As Single
StartTime = Timer
Do While (Timer - StartTime) * 1000 < lngTime
DoEvents
Loop
End Sub
喂我袋盐 发表于 2023-11-4 20:05:51
支持
刘大官人 发表于 2023-11-5 08:20:35
盲区
吴嗒嗒 发表于 2023-11-5 16:57:57
牛逼,这是什么东西?你们这时solidwork直接对接生产吗?
查看完整版本: SW关于输出曲面点阵到txt文档的宏代码
