inventor2020工程图转化CAD图问题
由于工作需要经常需要把inventor的工程图转化成CAD dwg格式可修改的图,中间碰到几个问题:1.inventor的工程图直接用CAD软件打开无法修改,没有模型图,只有布局图(只能选取到标记线,无法选取实体线)。2.如过改用inventor工程图导出CAD DWG格式图,是可以修改图形。但是又会出现中心线会变成实线,表示剖面的斜线会消失的情况。
不知有没朋友也遇到这些问题。会知道原因的请指导下。
正常CAD打开这样:
data:image/png;base64,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
导出CAD DWG格式会变这样
data:image/png;base64,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
我去,作为CAD亲儿子的INVENTOR,工程图的支持居然这么弱。 本帖最后由 初次登录 于 2023-6-22 08:18 编辑
去什么,不是精通inventor的话,就不要乱说话,inventor能输出两种dwg格式,inventor dwg和cad dwg
所以要确定楼主输出的哪种dwg格式,inventor dwg当然只能被inventor编辑。
楼主也在设计轴承压盖吗,可以交流一下,我用inventor2023
所 ...
2种格式都有问题,inventor DWG格式就是用CAD打开不能修改,CAD DWG格式我这里线型全变成实线。剖面斜线有的时候也会变没。就是不知道什么原因会导致这样。每转一张都要去改线型麻烦的很。
那啥吴伯雄,好像也对IN的技术支持很失望来着。。。。 本帖最后由 fangyunsheng 于 2023-6-25 13:06 编辑
INVENTOR是目前转dwg最完美的,遇到问题先别急着否定。
剖面线的问题,我也遇到过,只是你转换的时候配置文件没有选好。
有一点特别容易被忽视,就是手动另存的时候,要点“文件”,出来的弹窗一定要悬停在“另存为”上面,在点出来的“保存副本为”,就有各种格式的转换选项了。
另存文件选择“AUTO CAD文件(*. dwg格式)”,注意下面的选项,点击,出来“DWG工程图文件导出选项”,有配置一项,默认是“*.ini”文件,如果没有,转换以后我遇到的问题就是剖面线异常,跟你的一样,点后面的按钮,找到默认的ini文件,我正确配置以后,DWG全部正常 ytzhanggj007 发表于 2023-6-23 08:37
2023似乎有BUG,装配体,尚未约束完毕的部件,不能被拖动了(原本尚未完全约束的部件在尚未约束的方向是可以拖动的),约束的部件在阵列后也有问题,已经改成2022了。
剖面线的问题,我也遇到过,只是你转换的时候配置 ...
首先感谢您的回复和分享。我按照你的方法试用的下确实可以。我的线型问题,也在映射选项里找到了线型配置。
data:image/png;base64,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
万分感谢:handshake
:victory:
