3D打印常用的术语、简称、中英文对照
对3D打印中使用的所有概念,术语,简称,缩写,专业名词感到困惑?如果是这样,欢迎查看以下汇总的3D打印行业相关术语,包括中英文对照,建议收藏,以便学习查阅。https://mp.ofweek.com/Upload/News/Img/member99957845/202304/wx_article__5d6c0aca3aac674cc2eff3b187ebc766.jpg
1 - 3D打印技术
AM(Additive Manufacturing)增材制造CAD(Computer-aided Design) 计算机辅助设计CAM(Computer-aided Manufacturing) 计算机辅助制造CAE(Computer-aided Engineering) 计算机辅助工程FEA(Finite Element Analysis)有限元分析CFD(Computational Fluid Dynamics)计算流体动力学RE(Reverse Engineering)逆向工程DfAM(Design for Additive Manufacturing)增材制造设计
2 - 3D打印工艺
AJP(aerosol jet printing)气溶胶喷射打印AFP(Automatic Fiber Placement)自动纤维铺放BJ(Binder Jetting)粘合剂喷射成型(技术原理跟3DP相同)BPM (Ballistic Particle Manufacturing)弹道粒子制造
CLIP(Continuous Liquid Interface Production)连续液态界面生产CJP(ColorJet Printing)彩色粘接打印DLP (Digital Light Processing) 数字光处理DMD(Digita lMicromirror Device)可视数字信息显示技术DMLS (Direct Metal Laser-Sintering)直接金属激光烧结DED(Directed Energy Deposition)定向能量沉积DMD(Direct Metal Deposition)直接金属沉积DMLS:直接金属激光烧结DDM:直接数字制造DMP(Direct Metal Printing)直接金属打印技术DMT(Direct Metal Tooling)直接金属模具制造EBM (Electron Beam Melting) 电子束熔化EBAM(Electron Beam Additive Manufacturing)电子束增材制造EBSM(Electron Beam Selective Melting)电子束选区融化技术FFF (Fused Filament Fabrication)熔丝制造成型FDM (Fused Deposition Modelling) 熔融沉积成型FTI(Film Transfer Image)膜转印成像技术
HIP(Hot Isostatic Pressing)热等静压技术
LENS (Laser Engineered Net Shaping) 激光近净成型LOM (Laminated Object Manufacturing )分层实体制造LBM(Laser beam melting)激光束熔化LCF(Laser cladding forming)激光熔覆成形LLM(Layer Laminate Manufacturing)层压制造技术LMD(Laser Metal Deposition)激光金属沉积技术LPBF((Laser powder bed fusion)激光粉末床熔融LMF(Laser Metal Fusion)激光金属熔融技术
MJP(Multi-Jet Printing)多喷头打印成型MJF(Multi Jet Fusion)多射流熔融成型MIM(Metal Powder Injection Molding)金属粉末注射成型MJP(MultiJet Printing ) 多喷嘴喷墨3D打印
NPJ(Nano Particle Jetting)纳米颗粒喷射金属成型
PP(Plaster-based 3D printing)石膏成型PJ(PolyJet)聚合物喷射成型PJP(Plastic Jet Printing)塑料喷头打印PLS(Plastic Laser Sintering)针对塑材的选择性激光烧结
SLA ( Stereo Lithography Appearance) 立体光固化成型SLS(Selective Laser Sintering) 选择性激光烧结SLM(Selective Laser Melting )选择性激光熔化SHS(Selective Heat Sintering)选择性热烧结
TPP(Two-photon polymerization)双光子聚合光固化成形WAAM(Wire and Arc Additive Manufacturing)电弧增材制造
3 - 3D打印材料
高分子材料
ABS(Acrylonitrile Butadiene Styrene)丙烯腈-丁二烯-苯乙烯三元共聚物PLA (Poly Lactic Acid) 聚乳酸PA(Polyamide)聚酰胺纤维,俗称尼龙PP(polypropylene)聚丙烯PVA(Polyvinyl alcohol)聚乙烯醇PC(Polycarbonate)聚碳酸酯PEI(Polyetherimide)聚醚酰亚胺PPSF(Polyphenylsulfone)聚亚苯基砜PAEK(Polyaryletherketone) 聚芳基醚酮PBT(Permian Basin Royalty Trust)聚对苯二甲酸丁二酯PCL(Polycaprolactone)聚已内醋PEEK(Poly ether ether ketone)聚醚醚酮PEKK(Poly ether ketone ketone)聚醚酮酮PHA(PreliminaryHazardAnalysis)聚羟基脂肪酸酯PMMA(PolymethylMethacrylate)聚甲基丙烯酸甲醋PPS(Polyphenylenesulfide)聚苯硫醚TPU(Thermoplastic Urethane)聚氨酯
金属材料
Aluminum Alloy 铝合金Titanium Alloy 钛合金Stainless Steel 不锈钢Nickel Base Alloy 镍基合金Cobalt-chromium Alloy 钴铬合金
光敏树脂材料
EP Epoxy Resin 环氧树脂AA Acrylic Acid 丙烯酸脂
无机非金属材料
Ceramics 陶瓷Plaster 石膏Sandstone 砂岩Starch 淀粉
生物材料
Stem Cells 干细胞Biological Cell 生物细胞Silicone 硅胶Artificial Bone Ash 人造骨粉
新型3D打印材料
CNT Carbon Nanotube 碳纳米管Graphene 石墨烯
4 - 其他3D打印相关
G代码
G代码指令用于指导CAM系统的运行。在现代的设计软件中,G代码完全由软件生成,人们基本上都不再编写G代码。特定的G代码可以用来控制工具工作的速度、方向、深度、转动以及其它的开关和传感器。
切片器
3D打印机是通过片状层叠的方式进行累加的,切片器软件(Slicer)的工作就是将设计好的3D打印模型分割成各个单次打印的单层(单层厚度由打印精度确定)。切片器软件输出的控制路径、速度和打印温度的G代码。目前市面上闭源和开源的切片器软件都有。
STL(stereolithography)
这是3D打印最常见的格式,STL格式的文件通过一系列的三角形来描述模型的表面几何形状,不能保存颜色和任何纹路,只能保存三维模型的几何信息,是由3D SYSTEMS公司于1988年制定的一种为快速原型制造技术服务的三维图形文件格式。
OBJ(Object)
由Alias|Wavefront公司为3D建模和动画软件"Advanced Visualizer"开发的一种标准,适合用于3D软件模型之间的互导,这是一种标准3D模型文件格式。包含法线和贴图坐标,很适合用于3D软件模型之间的数据交换。
3MF(3D Manufacturing Format)
新一代3D打印文件格式,由微软牵头的3MF联盟,于2015年推出全新的3D打印格式——3MF。相较于STL格式,3MF档案格式能够更完整地描述3D模型,除了几何信息外,还可以保持内部信息、颜色、材料、纹理等其它特征。 楼主费心了
感谢分享 感谢,学习了 感谢楼主分享,谢谢 虽然看不懂,还是谢谢楼主的分享。 感谢分享,还是英文基础差啊 厉害 学习了,感谢分享!
