晓昀 发表于 2022-10-22 07:32:15
这个是什么三通?怎么翻译?
在一张国外图纸里看到一串英文,不知道怎么翻译?咨询了很多人,大家也不知道这个是什么?
Barred reduce tee,这个如何翻译?是管道里用的,好像是什么三通?
cherry 发表于 2022-10-22 07:35:32
Reducing tee with rod 带杆异径三通
百度翻译的,我理解是带栅条网的变径三通
CDKEY* 发表于 2022-10-22 07:54:57
Tee or Tee connection in piping engineering is a very important pipe fitting and is frequently used to combine or divide a flow. Two types of Tee are available, Equal Tee and Reducing Tee. However, in pigged pipelines, one special type of tee connection is widely used which is known as Barred Tee or Pigged Tee. In this article, we will try to study a few points about Barred Tee and Tee Connections.
https://whatispiping.com/wp-content/uploads/2020/01/2002.png?ezimgfmt=rs:476x250/rscb2/ngcb2/notWebPTypical Tee and Barred Tee Connection
Tee vs Barred TeeTee is a type of fittings that allows fluid to flow on its main pipe and branch out. The branch can be designed equally the same size as the main pipe (known as Equal Tee), or smaller size than the main pipe (known as Reducing Tee).Barred Tee is a special type of Tee that is based on a normal tee (can be either an equal tee or a reducing tee) that at a later stage, will be added with bar plates inside the branch outlet (From inside it looks like a steel cage) to restrict the pig from flowing from the header pipe into the branch pipes.Design Codes and Standards for Tee and Barred Tee
[*]The international standard dimension of the tee will be covered under ASME B16.9 or MSS-SP 75 (for DN16 and above). Click here to know more about Tee Connections.
[*]There is no international standard dimension for the barred tee. It is custom-made using the ASME B16.9/ MSS-SP 75 tee as a base. However, many develop their barred tee based on Shell DEP 31.40.10.13-Gen or ISO 15590-2 standard.
[*]This design can be a guideline to assess Vendor’s design.
https://whatispiping.com/wp-content/uploads/2020/01/2001-1024x726.png?ezimgfmt=rs:785x557/rscb2/ng:webp/ngcb2
Difference Between Tee and Barred TeeSo from the above discussion, we can summarize the following differences:
ParameterTeeBarred Tee
DefinitionStandard Pipe FittingA special type of piping component
ManufacturingGenerally by Extrusion or forgingMostly Fabricated
UseUsed in both piping and pipeline engineeringused in pipeline engineering near the pig launcher/receiver
Design Code / StandardASME B 16.9/MSS SP 75Shell DEP 31.40.10.13-Gen or ISO 15590-2
Production QuantityLarge scale in bulkSelect small quantities (custom-made)
CostCheaperCostlier than normal Tee
过球三通http://www.jiryy.com/uploads/allimg/151011/pig_tee01_C.png
管道通球试验和清管时,过球三通(又名档条三通、清管三通、格栅三通)可以防止卡球事故和引导清管器顺利通过主管线。按照管件口径分一般有等径三通,异径三通等。按照支管方向分有正三通和斜三通。
王IU 发表于 2022-10-22 07:58:18
还是大神多 要啥有啥上帝说要有光。。。。。。。
大白小白 发表于 2022-10-22 08:59:04
就是这个东东。
晓昀 发表于 2022-10-22 10:38:41
有道翻译翻译成“禁止异径三通”,就更不明白这是什么三通了。
查看完整版本: 这个是什么三通?怎么翻译?
