美国螺纹标准和英国螺纹标准有什么区别?
<P>新手,请教个问题.</P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: left; mso-pagination: widow-orphan" align=left><B><SPAN lang=EN-US style="FONT-SIZE: 10pt; COLOR: red; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-font-kerning: 0pt">3/4 inch SAE Threads (Standard American Threads)</SPAN></B></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: left; mso-pagination: widow-orphan" align=left><B><SPAN lang=EN-US style="FONT-SIZE: 10pt; COLOR: red; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-font-kerning: 0pt"><SPAN lang=EN-US style="FONT-SIZE: 10pt; COLOR: red; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">3/4</SPAN><SPAN style="FONT-SIZE: 10pt; COLOR: red; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-bidi-font-family: Arial; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial">英寸</SPAN><SPAN lang=EN-US style="FONT-SIZE: 10pt; COLOR: red; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 宋体; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">SAE</SPAN><SPAN style="FONT-SIZE: 10pt; COLOR: red; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-bidi-font-family: Arial; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial">螺纹(美国螺纹标准)</SPAN></SPAN></B></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: left; mso-pagination: widow-orphan" align=left><B><SPAN lang=EN-US style="FONT-SIZE: 10pt; COLOR: red; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-font-kerning: 0pt"><SPAN style="FONT-SIZE: 10pt; COLOR: red; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-bidi-font-family: Arial; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial"><FONT color=#000000></FONT></SPAN></SPAN></B> </P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: left; mso-pagination: widow-orphan" align=left><B><SPAN lang=EN-US style="FONT-SIZE: 10pt; COLOR: red; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-font-kerning: 0pt"><SPAN style="FONT-SIZE: 10pt; COLOR: red; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-bidi-font-family: Arial; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial"><FONT color=#000000>这个螺纹和英制的有区别吗?</FONT></SPAN></SPAN></B></P>
Re: 美国螺纹标准和英国螺纹标准有什么区别?
没有区别,一样Re: 美国螺纹标准和英国螺纹标准有什么区别?
美国螺纹一般指UNC,UNF,螺纹英国螺纹一般指PF,螺纹,也就是我们经常用的G螺纹,英制管螺纹
美国标准螺纹和英制螺纹是有区别的,主要是牙形角不同,前者60度、后者55度;再说,同样的公称规格,它们的螺距也不一样!Re: 美国螺纹标准和英国螺纹标准有什么区别?
美标和英标有区别的道理和我们的国标和日标是一样的,根本不是一个标准嘛Re: 美国螺纹标准和英国螺纹标准有什么区别?
楼主的问题问的也有问题美国标准 英国标准太广泛了美标太多了美标管牙,美标梯形(29度牙型),美标统一螺纹(UN,UNC,UNF,UNEF,UNS)等等等
英国标准一般常用的是 B.S.W,B.S.F,whit.S,whit都是55度的牙型角
建议楼主去买一本螺纹标准手册,看了就明白了Re: 美国螺纹标准和英国螺纹标准有什么区别?
那里有美制螺纹标准?Re: 美国螺纹标准和英国螺纹标准有什么区别?
说什么啊55度的管螺纹.英国螺纹是BSP.BSPP.日本是G跟PF.中国.法国.前苏联.日本是 用G来表示.
55度圆锥管螺纹是.中国ZG.英国是BSPT.法国G.德国是R.日本是.PT.R,
60度的圆锥管螺纹是,Z跟NPT,美国是NPT,苏联是B
55度梯形螺纹是,中国T跟TR,德国.前苏联.ISO.都是TR
都是美国的
标准锥管螺纹NPT
标准管接头用直管螺纹NPSC
标准管锁紧螺母用直管螺纹NPSL
标准导杆采用锥管螺纹NPTR
标准软管连接用直管螺纹NPSH
标准机械连接用直管螺纹NPSM
