735057167 发表于 2019-11-28 16:10:49
通过宏添加solidworks零件材料
由于模型需要测量总的重量,可通过宏来一键添加solidworks自带材料中304密度不是7。9需要自定义材料
也可以通过批量打开(dim)来实现
宏代码如下
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Sub 自适应材料()
    Dim N
    Dim a, b
    Dim name, NAME1
    Set swApp = Application.SldWorks
    Set Part = swApp.ActiveDoc
    Set selngr = Part.SelectionManager
    swApp.ActiveDoc.ActiveView.FrameState = 1
    N = swApp.ActiveDoc.GetTitle() '取得文件名
    Set swModel = swApp.ActiveDoc
    Set swConfig = swModel.GetActiveConfiguration
    CFGNAME = swConfig.name() '当前配置名称
    NAME1 = CFGNAME
    For i = 1 To Len(N)
      a = Mid(N, i, 1)
      b = Mid(N, i, 2)
      If a = "瓷" Then
            name = "A95瓷管"
            Exit For
   ElseIf a = "铜" Then
            name = "铜"
            Exit For
      ElseIf b = "环氧" Then
            name = "环氧板"
            Exit For
      ElseIf b = "云母" Then
            name = "云母"
            Exit For
      Else
            name = "SUS 304"
      End If
    Next
    boolstatus = Part.Extension.SelectByID2("未知", "BROWSERITEM", 0, 0, 0, False, 0, Nothing, 0)
    Part.SetMaterialPropertyName2 N, "C:/Program Files/SolidWorks Corp/SOLIDWORKS (2)/lang/chinese-simplified/sldmaterials/materials.sldmat", name
    Part.SetMaterialPropertyName2 NAME1, "C:/Program Files/SolidWorks Corp/SOLIDWORKS (2)/lang/chinese-simplified/sldmaterials/materials.sldmat", name
    Part.Save '保存
End Sub
由于无法上传宏文件,需要的可以留个邮件
叶飘零 发表于 2019-11-30 07:57:08
可以从这里粘贴代码
远祥 发表于 2019-11-30 11:23:36
直接添加零件材料,这个宏貌似更方方便。
knight3732449 发表于 2021-7-15 19:56:43
学习一下,顶一下
查看完整版本: 通过宏添加solidworks零件材料
